Thermocouple problems
@dc42 said in Thermocouple problems:
@stienfromarden said in Thermocouple problems:
Is it an option te reuse the type j termocouple wires to extend the pt1000? just for about 20cm to reach the termination box? these wires are steel braided and can handle some high temperature..
Doing so will introduce a small temperature error. The size of that error will depend on the temperature difference between the two ends of that thermocouple wire. It may be insignificant, I haven't done the sums.
@dc42 thank you very much for the answer!
I did not now if these:
https://docs.rs-online.com/f7e6/0900766b8155404c.pdf
pt1000's were ok I don't know much about them but I hope it will work! Can't wait to power up the extruder an PRINT!
Any PT1000 should be OK as long as it is electrically isolated from the hot end metalwork.
