    Print Removed 'Button'
    • laelundefined
      lael
      Is there a way to add a 'Print Removed' Button or similar to the PanelDue and Web Interface? Given that you can print remotely (IE, not in the same room), and in our situation, it is possible that multiple people will have access to the printer, it would be helpful to know if a printer has completed a print, and prevent it from starting another print until someone physically attends the printer and presses the button on the panel to say the print has been removed, so that people don't attempt to print on top of another print.
      • OwenDundefined
        OwenD
        You could create a macro button by creating a macro called "print-removed.g" in the root of the macros folder
        The macro could use M42 to set an output low when pressed (print removed)
        In start.g check if that output is high
        If it's already high, cancel print
        If it's not, set it high
        It's fraught with danger though
        What if the print was cleared but the beds not cleaned
        What about cancelled prints. etc
        A webcam would be a better check IMO
        • laelundefined
          lael
          Is there a way to integrate a webcam view into the interface?
            Phaedrux Moderator @lael
            @lael said in Print Removed 'Button':
            Yes.
            https://duet3d.dozuki.com/Wiki/How_to_include_a_web_camera_image_in_Duet_Web_Control
