M303: Run heater tuning
@LB said in M303: Run heater tuning:
So my suggestion is instead of
old:
"No heater has been tuned yet"
new
"No information since no heater has been tuned since startup"I will implement that suggestion immediately.
So does "Auto tune phase 1, heater on" means it just finished phase1, right(?), because if the system prints out "Heater 1 is being tuned, phase 2 of 4" just afterwards that must be the case. So could we change this
from
"Auto tune phase x, ..."
to
"Auto tune phase x finished, ..."
?I will change it to "Auto tune starting phase X".
The "Heater 1 tuning failed" message looks wrong to me. I will check when that message is generated.
BTW I have just started implementing the new heater tuning algorithm, which should be faster, more accurate (especially in measuring the dead time), use less RAM, and be more portable to expansion and tool boards.
@dc42 said in M303: Run heater tuning:
Thanks again! Sounds good - I will slowly finish the anycubic i3 mega conversion to have a solid base to migrate.
