    Stepper motors and endstops not appearing in dashboard
    Firmware installation
    dashboard
    • mogfrogundefined
      mogfrog
      I am attempting to connect stepper motors and endstops to a duet 3 board, but nothing turns up in the dashboard. I can control the motors using the console using commands such as G0 H0 X100 Y100 Z100 after adding the command M564 H0 to config.g , as per the information in the following link:
      https://duet3d.dozuki.com/Wiki/FAQ#Section_I_get_this_error_message_Error_G0_G1_insufficient_axes_homed
      Given that the motors can be controlled via the console, is there an additional step I should take to be able to control machine movement from the dashboard, and to get a readout from the endstops?
      I have followed the instructions on https://configtool.reprapfirmware.org/ in order to create the initial config files.
      See the config file generated below:
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Nov 04 2020 15:02:11 GMT+0000 (Greenwich Mean Time)
      M550 P"Duet 3" ; set printer name
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S1 ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X2000 Y2000 Z2000 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X230 Y210 Z200 S0 ; set axis maxima
      M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
      M574 Z1 S1 P"io2.in" ; configure active-high endstop for low end on Z via pin io2.in
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1
      M950 H0 C"!out0" T0 ; create bed heater output on !out0 and map it to sensor 0
      M308 S1 P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp2
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
      M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
      T0 ; select first tool
      • Rushmere3Dundefined
        Rushmere3D
        Being new to RepRap firmware myself I may be wrong but I wonder why you have a fan connected to the heater connector OUT3?
        Also I believe the PanelDue use the IO_0 by default so maybe move the endstop to a different IO.
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
          Phaedrux Moderator @mogfrog
          @mogfrog said in Stepper motors and endstops not appearing in dashboard:
          Can you be more descriptive on what you mean? It sounds like you have the motors moving, so they are connected.
          What are you expecting to see in the dashboard? What dashboard exactly?
          Is this a cartesian machine?
          Perhaps this commissioning guide would be helpful to you.
          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
            Which firmware and Duet Web Control versions are you using?
            • mogfrogundefined
              mogfrog
              Hi, Thank you all for the responses! I have checked all the above over the past few days and it turned out it hadn't updated and upgraded the firmware files. I started again and followed the following link to the letter and everything is working fine!
              https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3
              Thanks again,
              Mogs
