    Using the external switch on laser filament monitor
    Filament Monitor
    1.0k
      Phaedrux Moderator @Thalios
      @Thalios said in Using the external switch on laser filament monitor:
      I used a stainless steel rod as indirect which I sanded down to "de-polish" it. could that cause a problem?
      Photos?
      • Thaliosundefined
        Thalios
        Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
        Heavily modified Ender 3 Pro (Duet 3 6HC)
        Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
        CR-10S Pro V2 (Duet 3 Mini 5+)
        and a bunch of SLA printers..
          Yeah I could see how that could be problematic. Could you try adding a piece of dark matte tape it for a less shiny textured surface?
          • Thaliosundefined
            Thalios
            I think i'll put a black shrink tube on top of the rod to see how that goes.
            But I grinded it more with a dremel to remove all shininess and so far it hasn't faulted on me (I shouldn't jinx myself..)
            We'll see tomorrow!
            After 7.5h of printing, I have this:
            Duet3D laser filament monitor v2 on pin io3.in, enabled, allow 1% to 500%, check every 8.0mm, version 2, quality 224, brightness 63, shutter 123, measured min 145% avg 223% max 243% over 43342.3mm
            • Thaliosundefined
              Thalios
              2 successful prints in 48h. Very happy so far! I get a good reading with the dremel grinded rod.
              Now I need to make the same thing on my other 2 printers to get reliable results hehe.
              Thanks again!
                Glad it's working now.
