    Duet2Wifi not conenct to wifi after reset
    444
    • piperswundefined
      pipersw
      I use the Duet until today. 5 minutes ago before this port always was working, but I have do a emergency reset (like many others times) and now the blue led of the wifi don't light.
      With the USB, I can communicate with the board, but the wifi module remains disconnected :
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3SJ-6J9FL-3SD6J-1SXMF
      Used output buffers: 1 of 24 (1 max)
      Static ram: 27980
      Dynamic ram: 94500 of which 36 recycled
      Exception stack ram used: 248
      Never used ram: 8308
      Tasks: HEAT(blocked,1224) MAIN(running,1912) IDLE(ready,80)
      Owned mutexes:
      Last reset 00:01:00 ago, cause: power up
      Last software reset at 2020-11-07 15:21, reason: User, spinning module GCodes, available RAM 7952 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 32.8, current 36.3, max 36.3
      Supply voltage: min 0.0, current 0.0, max 0.1, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Cache data hit count 96685250
      Slowest loop: 3.50ms; fastest: 0.00ms
      === Storage ===
      Free file entries: 8
      SD card longest read time 3.1ms, write time 0.0ms, max retries 0
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by Trigger
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is doing "M116 P0" in state(s) 0 12 0, running macro
      Queue is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.00ms; fastest: 4581298.50ms
      HTTP sessions: 0 of 8
      - WiFi -
      Network state is disabled
      WiFi module is disabled
      Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
      === Filament sensors ===
      Extruder 0: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      ok
      M552 S0
      ok
      M552
      ok
      M552 S1
      ok
      M552
      ok
      M552 S-1
      ok
      M552
      ok
      M552 S0
      ok
      M552
      ok
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
      ok
      What's the issue ?
      I could read the sd card without issue on my pc.
      • piperswundefined
        pipersw
        M588 S"*"
        Error: M588: Failed to reset the WiFi module to factory settings
          Try sending M997 S1 to reflash the wifi module.
          • piperswundefined
            pipersw
            I have tried. How long does it take ?
            I wait one minute before disconnect the usb cable and reconnect.
            No change the WiFi is always disabled.
            What is the operating temperature of the board ?
            Mine has 45 degree ambiant and I have sometime overheat message of tmc
            A Former User? 2 Replies Last reply Reply Quote 0
            • A Former User?
              A Former User @pipersw
              @pipersw said in Duet2Wifi not conenct to wifi after reset:
              if you're using the usb serial console it should show you the progress, something like
              Trying to connect at 230400 baud:
               success
              Erasing 4096 bytes...
              Erasing 212992 bytes...
              Uploading file...
              5% complete
              10% complete
              15% complete
              20% complete
              25% complete
              30% complete
              35% complete
              40% complete
              45% complete
              50% complete
              55% complete
              60% complete
              65% complete
              70% complete
              75% complete
              80% complete
              85% complete
              90% complete
              95% complete
              Upload successful
              piperswundefined 1 Reply Last reply Reply Quote 0
              • A Former User?
                overheat message would indicate your drivers are reaching the 100C threshold set for the alarm afaik, you should probably consider some cooling. (45C ambient will reduce the the MTBF for any electronics, but it might still be beyond the usable lifespan for a given product)
                • piperswundefined
                  pipersw @A Former User
                  @bearer said in Duet2Wifi not conenct to wifi after reset:
                   success
                  Uploading file...
                  5% complete
                  10% complete
                  15% complete
                  20% complete
                  25% complete
                  30% complete
                  35% complete
                  40% complete
                  45% complete
                  50% complete
                  55% complete
                  60% complete
                  65% complete
                  70% complete
                  75% complete
                  80% complete
                  85% complete
                  90% complete
                  95% complete
                  Upload successful
                  I have nothing after the M997 S1....wifi chip dead ?
                  • piperswundefined
                    pipersw
                    Try a swap of ESP between a duet with working wifi and dead sd slot
                    • A Former User?
                      the first bit "trying to connect" should come from the duet afaik, i can see if I can test it on a duet 2 ethernet (without the ethernet module) later or tomorrow if your surgery doesn't bear fruits.
                      • piperswundefined
                        pipersw
                        sucess with the swap !!!!
                        now buy a sd slot and a ESP12S for repair the second board
                        need just to find the reference of ESP and sd slot card
                        the sd slot is Würth Elektronik 693071020811, I could put an another suplier ?
                        The ESP reference is just ESP12 ?
                        A Former User? 1 Reply Last reply Reply Quote 1
                        • A Former User?
                          ESP12S
                          you can use pretty much any ESP module with the same footprint, i.e. ESP12F and ESP12E, or ESP07 all work, but there differences in the certifications like ce/ul/fcc that matter for businesses.
                          You can use any SD card slot with the same footprint, but the Würth was chosen for superior quality, I opted for cheap chinesium* https://www.aliexpress.com/item/32972228521.html
                          (ed: * because ordering 1 of the Würth + shipping is crazy, however I will add a proper one next time I have to order from digikey anyway)
