    Timelapses, are they possible?
    Third-party software
    2.6k
    • A Former User?
      A Former User
      Good morning, in my Raspberry Pi3 I've installed MotionEye and it works well but it's really unuseful to take "printer-sync" timelapses....is there some other third party software to install on Raspy wich allows me to take timelapses sync with the layer change?
      I have read some options here but they require the insertion of some gcodes in the slicer with examples for Cura (with a given Phyton script) and Simplify 3D, I'm starting to use IdeaMaker so I don't know if this suits with this slicer...
      Any suggestion?
      Thanks!
      Andrea
      p.s.
      My raspy isn't connected via USB with the Duet so I can't use Octoprint (wich I didn't use because I want to "command" the printer via the Duet Web Control
      • Vetiundefined
        Veti
        see
        https://github.com/kriechi/DuetRRF-timelapse
        • A Former User?
          A Former User @Veti
          @Veti said in Timelapses, are they possible?:
          see
          It's exactly what I've read but I can't find a Wiki to understand how to use it...I'm not a Raspberry expert so for me the issue are:
          • Raspberry Pi / Single-Board Computer on the same network as your Duet
            with Python 3 and the requests package
          • Webcam that returns snapshot pictures (still image) via an URL
            mjpg-streamer or similiar: http://127.0.0.1:8080/?action=snapshot
          I think that I had to "throw away" motion eye, right? Or is it possible to use it feature to have an URL fort he still images?
          In case not should I install only Python 3 and mjpg-streamer to my Raspy?
          Thanks
          Andrea
          p.s.
          as you can see I'm not a Raspberry/Linux expert....sorry
          • Vetiundefined
            Veti
            @the_dragonlord said in Timelapses, are they possible?:
            if it can produce single images then no, otherwise yes.
            • A Former User?
              A Former User @Veti
              It produces single images
              But I can't undesrstand how the command M118 P4 S"LAYER CHANGE" ; take a picture could trigger the shooting of a pic....where do I have to put the URL given? In the web control? I am missing something...
              • Vetiundefined
                Veti
                the python script enables a telnet connection to the duet and listens for the "LAYER CHANGE" info
                the webcam url is an option for the python script
                • resamundefined
                  resam
                  I'm the author of https://github.com/kriechi/DuetRRF-timelapse - Ask me Anything 😃
                  Generating timelapse videos is quiet an opinionated topic in 3D-printing - everybody has a slightly different setup and preferred way of doing it. This is how I currently run my printer setup:
                  There are two things needed to make print-synced timelapses:
                  • your slicer needs to insert the M118 commands on every layer change
                  • your raspberry pi needs to run the timelapse.py script
                  You need to enable Telnet support in your Duet board with M586 P2 S1.
                  You can start the timelapse script on your RaspberryPi like this:
                  ./timelapse.py some-folder-for-all-images/ 192.168.1.42 http://127.0.0.1:8080/?action=snapshot
                  (with the IP address of the Duet printer, and the URL is in my case mjpg-streamer returning a single jpg image)
                  A Former User? 2 Replies Last reply Reply Quote 1
                  • A Former User?
                    A Former User @resam
                    @resam said in Timelapses, are they possible?:
                    ok, now the fog starts to raise a little....so, in order:
                    1. I can keep motion eye on my Raspy and install Python 3 and then copy timelapse.py on the Raspy SD
                    2. I have to insert the M118 in the layer change as you wrote on github:
                      M400 ; wait for all movement to complete
                      G4 P500 ; wait a bit
                      does this work on IdeaMaker too (I think so)
                    3. Do I have to execute manually each time the launch of the script and the timelapse rendering? Isn't it possible to execute them automatically in some way?
                    4. Least and last I didn't understand where the final timelapse MP4 will be stored...
                    Thanks for your help
                    • resamundefined
                      resam
                      1. I'm not familiar with motioneye - if you find a URL that you can call and it returns a single still frame as jpg or png, then yes.
                      2. I'm not familiar with IdeaMaker - most slicers have some "on layer change" script section were you can enter a few g-code commands
                      3. with a bit of Linux knowledge it should be easy to do - with varying levels of complexity. I would recommend searching the web for "crontab" or "systemd" in this context
                      4. All the still frames and the final rendered movie will be in the folder path you passed to the timelapse script as first argument
                      A Former User? 2 Replies Last reply Reply Quote 0
                      • A Former User?
                        ok, thanks! I'll do some searching and testing!
                        • A Former User?
                          Hi, I've installed everything but it doesn't work (of course I've missed something).
                          If can help when the I connect with putty I get this error message:
                          this is what I've inserted in etc/profile:
                          sudo python /home/pi/timelapse.py timelapses/ 192.168.1.7 http://192.1.168.13:8080/?action=snapshot
                          • resamundefined
                            resam
                            try with sudo python3 ....
                            python is the old version - python3 is the new one (which you need).
                            • A Former User?
                              This post is deleted!
                              • resamundefined
                                resam
                                go and run: python -V and then python3 -V
                                You will probably see that the first one returns 2.7.something and the other one 3.something.else.
                                We need 3.something for the timelapse script to work.
                                You can also avoid this monkey dance by simply calling the timelapse script itself:
                                sudo /home/pi/timelapse.py timelapses/ 192.168.1.7 http://192.1.168.13:8080/?action=snapshot
                                • A Former User?
                                  uh ok....I'm not a Linux expert....I've change from python to python3 and now no error appear logging into....I've started a trial print to see if all works...I'll let you know in few minutes!
                                  • A Former User?
                                    it's printing but I don't see images going into the folder as long as layers changes
                                    • resamundefined
                                      resam
                                      just start the script in the interactive console (putty) directly. It should print a few log lines so we can see what is happening.
                                      • A Former User?
                                        • resamundefined
                                          resam
                                          Did you enable Telnet in your printer config?
                                          • A Former User?
                                            yes
