    Artillery X1 Duet Maesto
    347
    • flopo76undefined
      flopo76
      Hello, i have an Artillery X1 with duet maestro RFF 3 firmware,when i try to heat up the nozzle the tool fan always start to 50%,even when i try to put it 100%,aftre the nozzle purged and the print start,the fan go to 50%.Need to increase manualy....
      My config file....
      ; Configuration file for Duet Maestro (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Sep 10 2020 08:29:26 GMT+0200 (Ora legale dell’Europa centrale)
      M550 P"Artillery X1" ; set printer name
      M552 P192.168.1.20 S1 ; enable network and set IP address
      M553 P255.255.255.0 ; set netmask
      M554 P192.168.1.1 ; set gateway
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S1 ; disable Telnet
      M569 P0 S0 ; physical drive 0 x goes forwards
      M569 P1 S1 ; physical drive 1 y goes forwards
      M569 P2 S0 ; physical drive 2 z goes forwards
      M569 P3 S1 ; physical drive 3 e goes forwards
      M350 X64 Y64 Z64 I1 ; configure microstepping without interpolation
      M350 E16 I1 ; configure microstepping with interpolation
      M92 X320.48 Y320.48 Z1619.35 E445.00 ; set steps per mm
      M566 X480.00 Y900.00 Z18 E420.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z2000.00 E12000.00 ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z350 E10000.00 ; set accelerations (mm/s^2)
      M906 X1100 Y1100 Z1100 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X300 Y300 Z400 S0 ; set axis maxima
      ;G31 X-28 Y33
      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H7 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-28 Y-33 Z1.285 ; set Z probe trigger value, offset and trigger height
      M557 X1:240 Y10:260 P3:3 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
      M106 P0 S0 H0:1 T50 ; set fan 0 value. Thermostatic control is turned on
      M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
      M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
      M563 P0 D0 H1 F0:1 ; define tool 0
      ; Custom settings
      M572 D0:1:2 S0.05
      ;M575 P1 S1 B57600 ; enable support for PanelDue
      ;M501 ; load saved parameters from non-volatile memory
      ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      ;M572 D0:1:2 S0.05
      • Vetiundefined
        Veti
        @flopo76 said in Artillery X1 Duet Maesto:
        i think this should be
        M106 P0 S1 H0:1 T50 ; set fan 0 value. Thermostatic control is turned on
        • flopo76undefined
          flopo76
          Ok i will try...thanks.
          • Vetiundefined
            Veti
            btw the tool fan speed is controlled by the slicer.
            • flopo76undefined
              flopo76
              Ok.S1 is active now,but when the print start the tool fan go to stop.This happend with all my printers. All with duet wifi or duet maestro. I use Cura for slicing.
              Example gcode with Cura:
              ;FLAVOR:RepRap
              ;TIME:8401
              ;Filament used: 10.0294m
              ;Layer height: 0.28
              ;MINX:90.864
              ;MINY:90.856
              ;MINZ:0.25
              ;MAXX:209.138
              ;MAXY:209.144
              ;MAXZ:10.89
              ;Generated with Cura_SteamEngine 4.8.0-beta
              T0
              M190 S85
              M104 S235
              M109 S235
              M82 ;absolute extrusion mode
              G28 ; home all axes
              M117 Purge extruder
              G92 E0 ; reset extruder
              G1 Z1.0 F3000 ; move z up little to prevent scratching of surface
              G1 X2 Y20 Z0.3 F5000.0 ; move to start-line position
              G1 X2 Y200.0 Z0.3 F1500.0 E15 ; draw 1st line
              G1 X2 Y200.0 Z0.4 F5000.0 ; move to side a little
              G1 X2 Y20 Z0.4 F1500.0 E30 ; draw 2nd line
              M83 ;relative extrusion mode
              G1 F1500 E-1
              ;LAYER_COUNT:39
              ;LAYER:0
              M107
              G0 F9000 X107.957 Y108.408 Z0.25
              ;TYPE:SKIRT
              G1 F1500 E1
              G1 F3600 X110.351 Y106.12 E0.13768
              G1 X110.519 Y105.968 E0.00942
              G1 X113.045 Y103.827 E0.13767
              G1 X113.223 Y103.686 E0.00944
              G1 X115.872 Y101.7 E0.13765
              G1 X116.058 Y101.569 E0.00946
              G1 X118.823 Y99.744 E0.13774
              G1 X119.016 Y99.624 E0.00945
              G1 X121.884 Y97.968 E0.13769
              Vetiundefined 1 Reply Last reply Reply Quote 0
              • flopo76undefined
                flopo76
                And why,when i want to power up the tool fan the print coller fan goes up?
                • Vetiundefined
                  Veti @flopo76
                  M107
                  That means fan off.
                    Phaedrux Moderator @flopo76
                    Fan0 should be the part cooling fan and Fan1 should be the heatsink fan. You've got them backwards.
                    Try this instead with the part cooling fan connected to Fan0 and the heatsink fan connected to fan1.
                    M106 P0 S0 H-1 T50 ; set fan 0 value. Thermostatic control is turned off
                    M106 P1 S1 H0:1 ; set fan 1 value. Thermostatic control is turned on
