Automatic Tool Z-Offset Correction
  • Hi,
    i want to use a "Tool Height Probe" (mechanical switch like in the picture below) to detect the actual Nozzle height for different tools at one 3D-Printer at a certain Temperature.
    I thought one possibillity to achive this is to override the Z-Offset in the config.g file at the selectet Tool.
    I would like to use G-Code Meta Commands: https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands
    But im not sure if it is possible, because variable declaration and assignment is not implementet yet.
    Also i would like to know if ther is another posibility to change the Tool Z-Offset without going into the config.g file and the need to restar the firmware.
    I use:
    Toolchanger (4 Tools)
    BL-Touch (Mesh bed compensation)
    Duet2 Ethernet Board
    I would be glad if you guys have some thoughts on this projekt. Also maybe there is someone who already implemented such system into a 3D-Printer or have a differernt way to achive it.
    @Philipp-R said in Automatic Tool Z-Offset Correction:
    Yes it's possible, and you don't need to use variables. The G10 command sets the trigger height, and object model variable sensors.probes[N].lastStopHeight will return the height at which the probe last triggered.
  • @dc42 is that line in the object model also applicable to G38.2 moves?
  • @dc42 thank you for the quick answer.
    Do i have to configure also the "Tool Heigt Probe" like the BL-Touch in the config.g with the M558 and G10 command.
    What i don't understand is were do i have to change the the Tool Z-Offset? directly in the config.g file or do i have override the value bevor printing?
    It would be great if you have more detailed information about this problem or also when tere is a thread who already a discussion is been made. Unfortunately i diddn't found the right information in the forum.
  • By the way i have found one thread about this topic: https://forum.duet3d.com/topic/18942/calculating-tool-offset-cnc/3?_=1604994474624
