PanelDue 7i garanti
I bought a paneldue 7i on the E3D online website with a duetwifi2 and a smart effector. It took me a long time to install everything. Now my printer works perfectly. So I was able to print a support to install the paneldue.
The problem is that the paneldue displays nothing but a white screen. I checked the connections, nothing could be simpler, and the problem is not there.E3D told me that I had to do a post here for the warranty service.
Thank you in advance for your answers.
How is it connected and does it show you the normal interface is you power it with only a usb cable connected?
@bearer said in PanelDue 7i garanti:
I connect it and feed it through the duet card.
I have just done the test with a simple usb connection and I have exactly the same result: white screen and nothing else. -
@fredo
please try a reset and update the firmware -
It sounds like the firmware was accidentally erased. Following the firmware update process should get it back working.
Thank a lot ! The screen works !
This morning I plugged my screen into my duet, everything lights up well but I don't have any information related to my printer (temperatures, etc.). I need to set up a few things?
what firmware did you install on the paneldue and what firmware are you running on the duet?
@Veti
RRF2.05 on DUET and 3.2 on paneldue.
I will try to install an older version I don't have a display but the stop and home commands work. -
@fredo said in PanelDue 7i garanti:
3.2 on paneldue requres at least 3.1.1 on the duet.
Everything it's OK.
Thanks
