    Enable debugging for all modules
    • TypQxQundefined
      TypQxQ
      Running on Duet3+RPi4 6HC+3HC with tools on 3HC. 3.2b3 but saw same behavior in 3.1.1.
      The manual states the following:
      "If the optional 'P' parameter is not specified, debugging will be enabled for all modules."
      But I get this:
      M111 S1
      Use P parameter to specify which module to debug
      It this a change not reflected in the documentation?
        Yes, the documentation was out of date. I have corrected it. Thanks for pointing this out.
        Enabling debugging for all modules is no longer useful because of the very large amount of output it produces.
