BLTouch doesn't deploy after update to 3.1.1 on Duet 2 WIFI
  • Hi,
    Recently updated my Duet 2 WIFI firmware because the printer kept losing wifi contact and frezed.
    I was running 2.03, now I have installed 3.1.1 using RRF 3.1.4.
    Thing is BLTOUCH is not working…. It’s always the BLTOUCH isn’t it?
    It was working all right on 2.04, after a little help from the community
    https://forum.duet3d.com/topic/13104/bl-touch-deploys-retracts-2x-when-turn-on-board-but-nothing-else
    My old config
    ; generated by RepRapFirmware Configuration Tool v2.1.3 on Thu Nov 28 2019 16:04:13 GMT+0000 (Hora padrão da Europa Ocidental)
    M550 P"AA 300x300x600" ; set printer name
    M575 P1 S1 B57600 ; Set Baud Route Duet Board
    M669 K1 ; select CoreXY mode
    M551 P"AA" ; set password
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P3 S0 ; physical drive 3 goes backwards
    M92 X80.00 Y80.00 Z400.00 E98.5 ; set steps per mm
    M566 X950.00 Y950.00 Z30.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z1000.00 E3300.00 ; set maximum speeds (mm/min)
    M201 X3100.00 Y3100.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
    M906 X1850 Y1850 Z1750 E1650 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X10 Y10 Z0 S1 ; set axis minima
    M208 X300 Y300 Z570 S0 ; set axis maxima
    M574 X1 Y1 S0 ; set active low and disabled endstops
    M574 Z1 S2 ; set endstops controlled by probe
    M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
    M558 P9 H5 F120 T10000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P25 X24 Y0 Z2.425 ; set Z probe trigger value, offset and trigger height (quanto mais elevado o valor, mais proximo da cama)
    M557 X90:210 Y70:230 S20 ; define mesh grid
    M307 H0 A105.5 C570.5 D0.2 V23.6 B0 ; disable bang-bang mode for the bed heater and set PWM limit
    M305 P0 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 0
    M143 H0 S110 ; set temperature limit for heater 0 to 110C
    M307 H1 A695.2 C202.3 D10.4 V23.6 B0 ; disable bang-bang mode for the bed heater and set PWM limit
    M305 P1 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 1
    M143 H1 S290 ; set temperature limit for heater 1 to 280C
    M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 S"Extr 1" D0 H1 F0 ; define tool 0
    M912 P0 S-25
    M572 D0 S0.2 ; linear advance
    T0 ; select first tool
    ; deployprobe.g
    ; called to deploy a physical Z probe
    M280 P3 S10 I1 ; deploy BLTouch
    ; homeall.g
    ; called to home all axes
    G91 ; relative positioning
    G1 H2 Z0.5 F6000 ; lift Z relative to current position
    G1 H1 X-300 Y-300 F1800 ; move quickly to X or Y endstop and stop there (first pass)
    G1 H1 X-300 ; home X axis
    G1 H1 Y-300 ; home Y axis
    G1 X5 Y5 F6000 ; go back a few mm
    G1 H1 X-300 F360 ; move slowly to X axis endstop once more (second pass)
    G1 H1 Y-300 ; then move slowly to Y axis endstop
    G90 ; absolute positioning
    G1 X20 Y20 F6000 ; go to first bed probe point and home Z
    G29 S1 ; reload the height map
    M376 H10 ; taper of bed compensation over a specified eight
    G1 S2 Z0.5 F100 ; lift Z relative to current position
    The new
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Nov 12 2020 10:45:00 GMT+0000 (Hora padrão da Europa Ocidental)
    M92 X80.00 Y80.00 Z400.00 E98.50 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X1750 Y1750 Z1750 E1750 I30 ; set motor currents (mA) and motor idle factor in per cent
    M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
    M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
    M558 P9 C"^zprobe.in" H0.5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X24 Y0 Z2.425 ; set Z probe trigger value, offset and trigger height
    M557 X50:250 Y50:250 S25 ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 C570.5 ; configure sensor 0 as thermistor on pin bedtemp
    M308 S1 P"e0temp" Y"thermistor" T100000 B4138 C202.3 ; configure sensor 1 as thermistor on pin e0temp
    ; deployprobe.g
    M280 P0 S10 ; deploy BLTouch
    ; homeall.g
    G1 H1 X-295 Y-295 F1800 ; move quickly to X or Y endstop and stop there (first pass)
    G1 H1 X-295 ; home X axis
    G1 H1 Y-295 ; home Y axis
    G1 H1 X-295 F360 ; move slowly to X axis endstop once more (second pass)
    G1 H1 Y-295 ; then move slowly to Y axis endstop
    G1 H1 Z-575 F360 ; move Z down stopping at the endstop
    G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
    G1 Z0.5 F100 ; lift Z relative to current position
  • @MJCT said in BLTouch doesn't deploy after update to 3.1.1 on Duet 2 WIFI:
    check with m122 and post the output that you are actually on 3.1.1
  • Hi,
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
    Board ID: 08DJM-9178L-L4MSJ-6J9F0-3S46Q-KT3YP
    Used output buffers: 3 of 24 (20 max)
    Static ram: 27980
    Dynamic ram: 93852 of which 68 recycled
    Exception stack ram used: 280
    Never used ram: 8892
    Tasks: NETWORK(ready,384) HEAT(blocked,536) MAIN(running,1840) IDLE(ready,80)
    Owned mutexes: WiFi(NETWORK)
    Last reset 00:01:18 ago, cause: power up
    Last software reset at 2020-11-12 13:26, reason: User, spinning module GCodes, available RAM 8884 bytes (slot 1)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
    Error status: 0
    MCU temperature: min 49.1, current 49.7, max 49.8
    Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-11-12 14:44:23
    Cache data hit count 128341946
    Slowest loop: 16.55ms; fastest: 0.14ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 3.7ms, write time 9.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    === AuxDDARing ===
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 203.59ms; fastest: 0.09ms
    Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is active
      Failed messages: pending 0, notready 0, noresp 1
      WiFi firmware version 1.23
      WiFi MAC address ec:fa:bc:01:d4:c6
      WiFi Vcc 3.38, reset reason Unknown
      WiFi flash size 4194304, free heap 24528
      WiFi IP address 192.168.10.62
      WiFi signal strength -50dBm, reconnections 0, sleep mode modem
    that is not what the configurator creates when you select bltouch.
    it should look something like this (notice the g30) check the configurator that you selected z probe and bltouch in the endstop tab
    ; homeall.g
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Nov 12 2020 15:48:47 GMT+0100 (Central European Standard Time)
    G1 H2 Z5 F6000          ; lift Z relative to current position
    G1 H1 X-235 Y-215 F1800 ; move quickly to X or Y endstop and stop there (first pass)
    G1 H1 X-235             ; home X axis
    G1 H1 Y-215             ; home Y axis
    G1 H1 X-235 F360        ; move slowly to X axis endstop once more (second pass)
    G1 H1 Y-215             ; then move slowly to Y axis endstop
    G1 X15 Y15 F6000        ; go to first bed probe point and home Z
    ;G91                    ; relative positioning
    ;G1 Z5 F100             ; lift Z relative to current position
    ;G90                    ; absolute positioning
    also your thermistor settings are incorrect B4138 is the default but you also specified a c value.
    find the correct values in your thermistor documentation
  • Iep, I know that the thermistor settings are all mesed up... that was my next step. One problem at a time.
    About the configurator
    What was my mistake?
  • very small images
    but it looks like you selects none for z instead of z-probe
  • Sorry!
    Yes I did, so that is at least one of my mistakes, ok
    Larger images
  • you still have selected none for z instead of z-probe
  • Nice!!!!!!
    After I change to Z-Probe and copying config, homeall, homez and retractprobe it seams to be working
    Thanks Veti
