    Duet2 Wifi PSU
    • R3playundefined
      R3play
      I'm thinking about replacing my PSU since it's just to big for my likings and the fan is way to loud on it.
      But since I'm not a huge expert in electrical stuff I tought I just ask here for some help.
      I'm thinking of buying a 24V 15A power supply, will this be enough?
      Running:
      Duet2 Wifi
      About 4 fans (1 Duet Wifi cooler, PSU fan, E3D v6 cooling fan and a part cooling fan)
      5 E3D stepper motors (Compact But Powerful motor ,
      • Step Angle: 0.9°
      • Rated Current: 1.68A
      • Body length: 40mm
      • Faceplate: NEMA 17
      • Motor cable length: 1m)
      Original E3D V6
      BLTouch
      220*220mm 24V Magnetic Heated bed
      (According to the seller it's a 120W Heated Bed)
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • piperswundefined
        pipersw
        I run a similar config but with a 400W 24V bed, and a MeanWell 500W PSU without issue.
        You just have to heat up the bed before all others actions.
        So I think it's enough IF you buy a good PSU, and not a noname.
        • Vetiundefined
          Veti @R3play
          @R3play
          that looks fine
          here is a guide on how to calculate it.
          https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
