SD card corrupted.
  • 3D printer was humming along nicely, until it wasn't. Homing just jammed the extruder to the mechanical end and after a powercycle there was no Wifi connection. Happened at the worst possible moment of course.
    Fished the board out, connected USB:
    https://www.icecoldcomputing.com/directlink/3dprinter/Duet_noSD1.png
    SD card (the one that came with the Duet) seems corrupted indeed:
    Not a really big deal; I had a backup, and witht he backup on another card the printer seems to work again.
    But quite a nuisance nonetheless. Any special reasons why the SD might have been corrupted? Duet is powered by a constant +5V, Vin is switched, so sudden power loss should not be an issue.
  • How old was it? All flash do wear out in the end.
  • The Duet is in use for about a year or so, I had it on the shelf a little longer. Not that many writes to the card though; printer is running for 25 hours a week or so average, but many prints are repeats.
    Do you have M929 logging enabled? That causes additional writes to the SD card.
  • I had M929 enabled during bringup of the printer, say 3-4 weeks. Not anymore. So not many writes should occur to the card, <100MB/month.
    Just a case of shorter-than-average lifetime of the card then, no special reason?
