Temperature error
  • I'm seting up my tronxy x5s with an duet 2 ethernet, but i can't figure out how to fix the temperature readings. I keep having the error: Temperature reading fault on heater 1: unknown temperature sensor channel. This is also for heater 0. Because of this the temperature reading are 2000C. The wiring and the thermistors are all good.
    What am I doing wrong?
    The config.g of the heaters:
    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
    M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
  • @SteenKlasse said in Temperature error:
    post a picture of the wiring.
    2000C means the thermistor is not connected.
  • I did not use the duet conectors but these make good contact, i have measured them.
  • If you are using the same connector for both sensors and neither works... and its not the correct connector....
    My first suggestion would be trying the correct connector.
  • post the output of m122
    your config version might not match the firmware version
  • M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet Ethernet 1.02 or later
    Board ID: 0JD0M-9P6M2-NW4SS-6JTD4-3S46J-KVYHM
    Used output buffers: 4 of 24 (8 max)
    Static ram: 25712
    Dynamic ram: 92688 of which 492 recycled
    Exception stack ram used: 272
    Never used ram: 11908
    Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3816) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:00:57 ago, cause: power up
    Last software reset at 2020-11-13 23:15, reason: User, spinning module GCodes, available RAM 11908 bytes (slot 2)
    Error status: 0
    Free file entries: 10
    MCU temperature: min 23.8, current 25.6, max 25.7
    Supply voltage: min 24.3, current 24.4, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-11-15 20:08:08
    Cache data hit count 107596781
    Slowest loop: 4.08ms; fastest: 0.07ms
    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
    === DDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 7.57ms; fastest: 0.02ms
    HTTP sessions: 1 of 8
    Interface state 5, link 100Mbps full duplex
  • @theruttmeister I have replaced the connectors but it doesn't work.
    your config is for firmware version 3 but you have firmware version 2 installed
    see
    https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
  • Is it better to update to version 3 or to select version 2 in the reprap configurator?
  • @SteenKlasse
    since you are setting up a new printer go with rrf3.
    be advised that you need to update to 3.0 first
  • @Veti Thanks
