    bltouch config
    Firmware installation
    1.0k
    • Petarundefined
      Petar
      Does anyone have a tutorial how to config a bltouch on a duet 2 wifi with the config tool.
      I have a ender 3 v2 and im upgrading it like the linear rail full setup.
      i cant find nothing on youtube or here on this forum.
      I just bought this board and i'm learning how to configure it i have updated the board to 3.11 took me 3 hours to read and how to do it, was a little afraid to brick my board
      so does anyone has a link with a tutorial how to or can explain what to select and to add in the firmware if have to.
      I found some video's on youtube from a guy ''Design Prototype Test'' but he does not show how to configure the bltouch you have to be a patreon to get it. 😞
      hope some one can help me out.
      • Vetiundefined
        Veti
        see
        https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
        • Petarundefined
          Petar
          i have read that still dont understand what to do in the online config tool
          Kolbiundefined 1 Reply Last reply Reply Quote 0
          • Kolbiundefined
            Kolbi @Petar
            @Petar,
            The last few pages of the attached shows how to connect and configure the bltouch. Hope this helps.
            Duet-MK3s.pdf
            Cheers,
            Kolbi
            Petarundefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti
              select pwm control channel in the i/o mapping
              then under endstops you can select the bltouch
                https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s220
                There is some walk through here (as well as many other things in this guide) which may get you going.
                The config part of it is pretty basic though. The main thing we need to know is what pins you are using. Usually it would be pin 3 or pin 7 on the expansion header for the servo control wire.
                In config.g
                M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
                M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
                And then the two deploy and retract files.
                ; deployprobe.g
                ; called to deploy a physical Z probe
                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 13:35:03 GMT-0600 (Central Standard Time)
                M280 P0 S10 ; deploy BLTouch
                and
                ; retractprobe.g
                ; called to retract a physical Z probe
                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 13:35:29 GMT-0600 (Central Standard Time)
                M280 P0 S90 ; retract BLTouch
                Petarundefined 1 Reply Last reply Reply Quote 1
                • Petarundefined
                  Petar @Phaedrux
                  @Phaedrux
                  i becomes more and more confusing now
                  where do i find this in the online config tool ?
                  Vetiundefined 1 Reply Last reply Reply Quote 0
                  • Vetiundefined
                    Veti @Petar
                    @Petar
                    see my post from above
                    • Petarundefined
                      Petar @Kolbi
                      @Kolbi
                      i does not say anything about the online config tool
                        Making those selections should create the config files you need.
                        The text I showed in my other post is what get generated.
                        • Petarundefined
                          Petar @Phaedrux
                          @Phaedrux
                          thanks
                          is this all that i have to do or do i have to make some changes in the config file ?
                          • Vetiundefined
                            Veti @Petar
                            @Petar
                            the generated files (all of them) are enough if you have set the parameters correctly
                            • Petarundefined
                              Petar @Veti
                              @Veti
                              Thanks i still dont understand why there is not a tutorial like with pictures how to for a noob like 🙂 thanks again everyone
                              • Kolbiundefined
                                Kolbi @Petar
                                @Petar, sorry - I didn't fully digest your question in that it was pertaining strictly to the online config tool. If you get stuck, give a look at pages 18 and up - these were my lessons learned with getting bltouch operating.
                                Cheers,
                                Kolbi
                                • Petarundefined
                                  Petar @Kolbi
                                  @Kolbi
                                  🙂 what do you mean by pages 18 and up ?
                                  do you have a link for me ?
                                  thanks
                                  • Kolbiundefined
                                    Kolbi @Petar
                                    @Petar, my first post had a pdf attached. 😉
                                      Phaedrux Moderator @Petar
                                      @Petar said in bltouch config:
                                      @Veti
                                      I also posted a 5 part guide on getting an ender 3 up and running with a maestro on RRF2. It's not exactly the same as the wifi on RRF3 but a lot is applicable.
                                      https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
                                      At some point you'll have to climb the mountain of learning.
                                      Petarundefined sylvaindcundefined 2 Replies Last reply Reply Quote 0
                                      • Petarundefined
                                        Petar @Kolbi
                                        @Kolbi
                                        i missed that thanks
                                        • Petarundefined
                                          Petar @Phaedrux
                                          @Phaedrux
                                          Ok will read that thanks
                                          • Kolbiundefined
                                            Kolbi @Petar
                                            @Petar, no worries at all. Hope you get it working!
