    Debug MAX31865 over CAN
    331
    • ybundefined
      yb
      My 3D printer is equiped with a Duet 3 MB 6HC and one Duet 3 EB 3HC.
      On the extruder, I use 3 PT100 sensors and a fourth one for the heated build plate. All PT100 sensors are connected to the Duet 3 boards through a MAX31865.
      On this printer, I can read all the temperatures of the PT100 sensors.
      When I heat the extruder and extrude, I can still read all the temperatures normally.
      But, once I start a print, I have two sensors on the extruder showing me 2000°C and the third one 0°C. Shortly after, I lose the connection on the Mother Board and the print is stopped.
      The last time I got that error message : Error: M308: Response timeout: CAN addr 1, req type 6011, RID=901
      The previous time I had this one : Failed to upload dwc2settings.json
      Operation failed (Reason: Your Duet rejected the HTTP request: Unknown message type or not authenticated)
      Once the sensors are showing me these anormal values I wasn't able to reset them, even with a M562, unless reseting the whole printer.
      Here is what I get when trying a M308 S4 : Sensor 4 type PT100 (MAX31865) using pin 1.spi.cs2, last error: success, 2/4 wires, reject 50Hz, reference resistor 400 ohms
      The issue only concerns the sensors that are connected to the Duet 3 EB 3HC. The build plate sensor doesn't have any problem.
      I am kind of stuck here so any help would be appreciated.
      Thanks,
      • ybundefined
        yb
        [Edit] : It seems that there is a CAN connection failure right when the temperature sensors start showing the incorrect values.
        Once the CAN connection is working again the temperatures are either incorrect either non existent ( no sensor is found.
          What firmware versions are you running on the main and expansion boards?
          • ybundefined
            yb
            Thank you for taking time to answer.
            The firmware versions of the mother board and the expansion board are respectively :
            • FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.0 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-05-15b1
            • Board EXP3HC firmware 3.0RC1 2019-12-16b1
            • Vetiundefined
              Veti
              from the changelog
              https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md
              RepRapFirmware 3.2-beta2
              M111 supports CAN module debug
                Time for a firmware update to at least 3.1.1
                https://github.com/Duet3D/RepRapFirmware/releases/tag/3.1.1
                • ybundefined
                  yb
                  I tried to update the firmware to 3.1.1 for the expansion board and still had the problem but without having the sensors temperatures showing 2000°C.
                  With the firmware 3.2-beta3.2 on both the expansion and the mother boards it seems that the issue is gone.
                  Thanks a lot for the answers!
                    I'm glad it seems to be solved. Please upgrade to 3.2beta 4, which fixes issues in 3.2beta 3.2.
