    Problem with emergency buttom
    • qlfecvundefined
      qlfecv
      When I use this setting for an emergency button, the board locks when it is working.
      Is correct it?
      M950 J1 C"!^exp.heater4" ; Stop buttom pullup active low
      M581 P1 T0 C0 ; Emergency stop on trigger anytime
      Jose
        Firmware version? Send M115 to check.
        How you format the command will depend on your firmware version.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_Configure_external_trigger
        • qlfecvundefined
          qlfecv
          Thanks you C0 parameter was the problem.
          Jose
