    HOW TO CHANGE NAME IN DUET3&DUET PI
    536
    • huai3895undefined
      huai3895
      I got more than 20 fdm ,so i need use differnt name to administration this ,however {m550 p"name"} cant named now.
      It tell me(Machine name must consist of the same letters and digits as configured by the Linux hostname)
      So ,i try to change name of duet pi(sudo nano /etc/hosts,127.1.1.1 name),but it will make the webcontrl out line.
      Can any master teacher me,orz.
      huai
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @huai3895
        @huai3895
        you should name them on the dhcp server.
        assign static leases with specific hostnames to the mac address of each printer.
        huai3895undefined 1 Reply Last reply Reply Quote 0
        • huai3895undefined
          huai3895 @Veti
          @Veti I have try this already ,still easy to make error operation cause i cant distinguish at a glance
          • A Former User?
            A Former User
            edit /etc/hostname and reboot; or run sudo raspi-config choose (2) Network Options then Hostname
            huai3895undefined 2 Replies Last reply Reply Quote 0
            • huai3895undefined
              huai3895 @A Former User
              This post is deleted!
              • huai3895undefined
                @bearer thanks it work nice
                • Vetiundefined
                  Veti
                  @huai3895 said in HOW TO CHANGE NAME IN DUET3&DUET PI:
                  thanks it work nice
                  thats exactly what a static dhcp lease does as well
                  huai3895undefined A Former User? 2 Replies Last reply Reply Quote 0
                  • huai3895undefined
                    huai3895 @Veti
                    @Veti Mabe i am a noob ,i didt understand how to concrete operations
                    • A Former User?
                      A Former User @Veti
                      @Veti said in HOW TO CHANGE NAME IN DUET3&DUET PI:
                      not necessarily; while the dhcp server can send a hostname back to the client, its still up to the client to actually configure the system to use it, which doesn't seem to be default behaviour on debian (and derivatives like duetpi).
                      edit: If the hostname is currently blank, (null) or localhost, or
                      force_hostname is YES or TRUE or 1 then dhcpcd sets the hostname to the one supplied by the
                      DHCP server.
                      so because the hostname is set to duet3, dhcpcd ignores what the server is sending.
                      while most modern consumer routers will put the hostname into their dns service it doesn't actually change the hostname for the dhcp client. for other clients it will resolve, but not locally on the client in question without modifying the setup to honour the dhcp option received (the dhcp hooks seems to have changed since the move to dhcpcd)
                      edit: new hooks are /etc/dhcpcd.enter-hook and /etc/dhcpcd.exit-hook, putting hostname $new_host_name in the enter-hook gives you a server enforced hostname and the router resolves it. could echo it to /etc/hosts for good measure i guess.
                      Reset hostname to localhost to let dhcp control hostname seems to be the clean solution.
                      • Vetiundefined
                        Veti @A Former User
                        @bearer said in HOW TO CHANGE NAME IN DUET3&DUET PI:
                        debian
                        ah the nice think about each linux distribution to do things differently
                        • A Former User?
                          A Former User
                          come to think of it, the current behaviour might be best as not all users can control the hostname sent from the router and if its not duet3 as the default for the config tool it would break, worst case scenario preventing parsing the rest of the config and bringing up the network.
