    Out vs io.out
    • Donpiundefined
      Donpi
      Juste wandering...
      I have the blTouch on IO_7 and a fan on OUT7.
      Is it normal that when I deploy the probe it starts the fan ?
      Bye.
        No, that's not normal. IO7.out is completely separate from OUT7.
        Donpiundefined 1 Reply Last reply Reply Quote 0
        • Donpiundefined
          Donpi @dc42
          @dc42 Ok I found what is appening.
          The problem is not between IO_7.out and OUT7.
          But between IO_7.out and OUT4.
          In OUT4 I have a LED strip, with I declare like that on pin 0.
          M950 P0 C"out4" Q500
          And my blTouche is declared like taht on servo 0.
          M950 S0 C"io5.out"
          The real problem ( if we say there is one) is between servo and pin when they have the same ID. In my case servo 0 and pin 0.
          Of course I solved this changing my pin's ID.
          Bye
          Juan
            Thanks for clarifying that. I have update the documentation for M950 to clarify that servo pins are just GPIO pins with a different default PWM frequency. I will mark this as solved.
