Z Axis Homing problem
Video here: https://photos.app.goo.gl/cQQuQ35AqF7eZz2Z8
I have an issue with z homing, my axis stops before pressing the endstop.
My g-code is stock, from the rrf3 tool.Any help is appreciated!
See the video to understand better.
post all your homing files and your config.g
Just guessing but you may simply not be allowing enough movement in your homez.g file to reach the end stop.
My config.g:
; generated by RepRapFirmware Configuration Tool v3.1.8 on Fri Nov 20 2020 17:22:39 GMT+0000 (Horário Padrão da Europa Ocidental); General preferences
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X220 Y220 Z260 S0 ; set axis maxima; Endstops
M574 X1 S3 ; configure sensorless endstop for low end on X
M574 Y1 S3 ; configure sensorless endstop for low end on Y
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:215 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
; homez.g
; called to home the Z axis
G91 ; relative positioning
G1 H1 Z-265 F1800 ; move Z down until the endstop is triggered
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning -
post the output of M119
@vladivakh The problem is: I haven't a z probe!
@vladivakh said in Z Axis Homing problem:
your endstop is already triggerd. try inverting the endstop using
M574 Z1 S1 P"!zstop" -
