    M226 not working for me 3.2b3.2 duet2wifi standalone
    Beta Firmware
    • Adrian52
      Adrian52 last edited by
      Pause and resume works fine from dwc, but pausing a print using M226 in gcode doesnt work. Printer pauses, console says 'resume state saved', but head stays on print, suggesting that pause.g is not running. Console is then generally unresponsive, so print will not resume. Can reset with M999. M122 gives
      22/11/2020, 21:28:40 	m122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta3.2 running on Duet WiFi 1.0 or 1.01
      Board ID: 08DAM-999TL-MQ4SD-6J9FD-3SJ6J-K593W
      Used output buffers: 3 of 24 (12 max)
      Static ram: 24108
      Dynamic ram: 100388 of which 40 recycled
      Never used RAM 5512, free system stack 116 words
      Tasks: NETWORK(ready,183) HEAT(blocked,308) MAIN(running,422) IDLE(ready,20)
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:14:29 ago, cause: software
      Last software reset at 2020-11-22 21:14, reason: User, GCodes spinning, available RAM 5512, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
      Error status: 0x00
      MCU temperature: min 31.2, current 34.3, max 34.3
      Supply voltage: min 24.1, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 63212, standstill, SG min/max 0/210
      Driver 1: position 64922, standstill, SG min/max 0/1023
      Driver 2: position 64018, standstill, SG min/max 0/1023
      Driver 3: position 0, standstill, SG min/max 0/272
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2020-11-22 21:28:40
      Cache data hit count 1368115331
      Slowest loop: 133.29ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 8
      SD card longest read time 1.0ms, write time 10.1ms, max retries 0
      Hiccups: 6(0), FreeDm: 169, MinFreeDm: 139, MaxWait: 208783ms
      === MainDDARing ===
      Scheduled moves 2033, completed moves 2033, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      Heater 0 is on, I-accum = 0.4
      Heater 1 is on, I-accum = 0.5
      Segments left: 0
      Movement lock held by File
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0 21, running macro
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 206.94ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.24
      WiFi MAC address 5c:cf:7f:2c:24:6b
      WiFi Vcc 3.37, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 25064
      WiFi IP address 192.168.1.16
      WiFi signal strength -53dBm, reconnections 0, sleep mode modem
      Clock register 00002002
      === Filament sensors ===
      Extruder 0: pos -0.66, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      • Adrian52
        Have now done some rolling back and forwards. M226 pause from gcode works for me in 3.1.1 and 3.2b2, but not in 3.2b3 or 3.2b3.2. Pause and resume working from dwc in all versions.
        • Adrian52
          A further piece of information, retesting 3.2b3.2 - a pause induced by deliberate triggering of my laser filament monitor worked properly, and allowed an appropriate resume. An embedded M226 later in the same print caused the freeze seen before, which I have only been able to recover from by resetting.
          Could someone else test M226 on 3.2b3.2.
            Yes, it's broken, stuck on "pausing". I will fix it in the next beta.
            Adrian52 1 Reply Last reply Reply Quote 0
            • Adrian52
              Adrian52 @dc42 last edited by
              @dc42 thank you
