    BLTouch on Duet2Wifi / TEVO Little Monster
    Firmware installation
    229
    • avery1701undefined
      avery1701
      This was working on firmware 2.05.1 and just upgraded to 3.1.1. The BLTouch will deploy (M401) and retract (M402) and enter test mode (M280 P0 S120), but when I enter G30 it fails with "Error: Z probe already triggered at start of probing move" without ever deploying the probe.config.g
      retractprobe.g homedelta.g deployprobe.g
      • Vetiundefined
        Veti
        change to
        your thermistor config is incorrect. find the correct beta value in your thermistor documenation.
        M665 R155 L397.19 B155 H520 ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
        this is not the result of delta calibration, and you are not overwriting these settings with M501
        Phaedruxundefined 1 Reply Last reply Reply Quote 1
          avery1701
          I cannot run delta calibration because G30 fails. Bed and nozzle heating are working correctly.
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @avery1701
            @avery1701 said in BLTouch on Duet2Wifi / TEVO Little Monster:
            but you dont have the values from your 2.05.1 firmware?
              Phaedrux Moderator @Veti
              @Veti said in BLTouch on Duet2Wifi / TEVO Little Monster:
              Fixing that should allow G30 to work.
              The exclamation point you have in there means invert the signal, so when you go to try to probe with G30, it's already triggered.
              avery1701undefined 1 Reply Last reply Reply Quote 0
                avery1701 @Phaedrux
                @Phaedrux said in BLTouch on Duet2Wifi / TEVO Little Monster:
                That fixed it. Thanks @Phaedrux! That line was automatically generated by the configuration, but I am not sure what I selected to cause it to add the inverted zprobe flag. The config looks nothing like the 2.05.1 firmware config.
                Phaedruxundefined 2 Replies Last reply Reply Quote 0
                  Phaedrux Moderator @avery1701
                  Yes, RRF3 is a bit different. Mainly in how pins are assigned and how heaters and fans are defined. Overall it is more logical and flexible.
                  You can see more on what has changed here: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                    On the IO mapping page in the z probe section you would have selected Input pin: zprobe.in (inverted)
