    extruder not heating after replacing fuse
    • peterartechnoundefined
      peterartechno
      I have a duet 2 wifi with the latest firmware. When re-assembling my hotend, the wires of the hotend touched each other resulting in a blown fuse (the 7.5A). I replaced the 7.5A fuse with a new one. This solved the problem that I had no 3.3V and 5V light. This is solved.
      The problem I am facing now is that my E0 heat is not blinking or heating. I did print already with my current config.g file, doublechecked it, still on e0heat. I do not know why, but there is also no current flowing through the E0 heating output. Is there something besides the 7.5A fuse that I don't know about?
      thanks in advance
        peterartechno
        okay never mind. It works now, maybe it takes some time to work through the fuse.
