    DSF .Net Core : Event suscribtion
    DSF Development
    1
    • Donpi
      Donpi last edited by Donpi
      I am trying/playing with the Duet Server Framwork with .Net Core.
      I dont get how to suscribe to the events.
      Here is my code, see near the end of Main where I suscrib to the event.
      The event is never fiered, even when the temperature change.
      If someone can tell me where I'am wrong :
      static void Main(string[] args)
               Console.WriteLine("Début");
               Console.WriteLine("Connection");
               SubscribeConnection oCon = new SubscribeConnection();
               try
                        Task oTaskCon = oCon.Connect(SubscriptionMode.Full,"/var/run/dsf/dcs.sock");
                        oTaskCon.Wait();
               catch (Exception oE)
                        Console.WriteLine("-----------------------------");
                        Console.WriteLine("---- erreur de connection ---");
                        throw oE;
               if (oCon.IsConnected)
                        Console.WriteLine("Connection OK");
               else
                        Console.WriteLine("Connection échouée");
               Console.WriteLine("Recupération du modèle");
               Task<MachineModel> oTask = oCon.GetMachineModel();
               oTask.Wait();
               MachineModel oModel = oTask.Result;
               Console.WriteLine("Lecture des capteurs");
               Sensors oSensors = oModel.Sensors;
               Console.WriteLine(oSensors.Analog.Count.ToString() + " Analog sensors");
               Console.WriteLine(oSensors.Endstops.Count.ToString() + " Endstops sensors");
               Console.WriteLine(oSensors.FilamentMonitors.Count.ToString() + " FilamentMonitors sensors");
               Console.WriteLine(oSensors.GpIn.Count.ToString() + " GpIn sensors");
               Console.WriteLine(oSensors.Probes.Count.ToString() + " Probes sensors");
               Console.WriteLine("Capteurs Analogiques");
               AnalogSensor oMCU = oSensors.Analog[3];
               oMCU.PropertyChanged += OMCU_PropertyChanged;
               Console.WriteLine(oMCU.Name + " : " + oMCU.LastReading + " C°");
               for (int i = 0; i < 400; i++)
                        Thread.Sleep(50);
               Console.WriteLine("Fin");
      private static void OMCU_PropertyChanged(object sender, System.ComponentModel.PropertyChangedEventArgs e)
               AnalogSensor oMCU = sender as AnalogSensor;
      Bye
      Juan
      Donpi 1 Reply Last reply Reply Quote 0
      • Donpi
        Donpi @Donpi last edited by
        @Donpi Dear myself, try this way :
                    try
                        oTaskCon.Wait();
                        throw oE;
                    else
                    oTask.Wait();
                    Console.WriteLine("Updating model");
                    while (true)
                        Task<JsonDocument> oTaskPatch = oCon.GetMachineModelPatch();
                        oTaskPatch.Wait();
                        oModel.UpdateFromJson(oTaskPatch.Result.RootElement);
                        Thread.Sleep(250);
                    Console.WriteLine(oMCU.Name + " : " + oMCU.LastReading + " C° from event");
