    Strange behavior with CAN-bus
    Beta Firmware
    263
    • medicusdkfzundefined
      medicusdkfz
      I get a strange message, that I hadn't before
      I installed the latest beta4 for RRF3.
      Kindly regards,
      Pierre
        medicusdkfz
        Oh sorry! My boards are a 6HC and a 3HB...
          Reboot the main board if you haven't done so since the expansion board firmware was updated, and use M115 and M115 B1 to check what firmware versions are installed.
            medicusdkfz
            @dc42 said in Strange behavior with CAN-bus:
            M115
            Can't install the new 3HB-firmware... Have 3.0RC1 (M115 B1) after uploading the file from the release 3.2 beta4 (Duet3Firmware_EXP3HC) to the system folder...
            M115 showed the 3.2beta4 for the 6HC...
              Are you running with or without attached SBC?
                medicusdkfz
                standalone 6HC
                  medicusdkfz
                  The 3.2Beta4 from 6HC starts immediately with flashing the EEPROM after uploading but not the 3HC... The same issue, when I downgrade to 3.2beta2.2... Do I need other files for the flashing of the 3HC inside the system folder?
                  These files are inside:
                    medicusdkfz
                    Problem solved. I have forgotten M997 B1... Now it's working!
                      Thanks, I'll mark this as solved.
