M307 S does not work
Hello
I have a problem using the M307 S command. I am using a peltier module to cool down the bed and it works fine when S1 is used. However, if I use for example S0.5, the heater (cooler) is just turned on at all times. Any idea why that is?
Thanks in advance
/Frederik -
disable Bang Bang to enable PWM.
B0 instead of B1
also your thermistor setting is wrong. B4138 is the default. Look up the correct value in your thermistor documentation.
Peltier modules behave very poorly with PWM, unless you smooth the output of the PWM using a diode, inductor and capacitor.
