    topic_solved Can't get BLTouch to work
    • Roy
      Roy last edited by Roy
      Hello I am Roy and can someone help me make the BLtouch work?
      G30 commands continues to indicate: Z probe already triggered at start of probing move.
      Pin also not deploying ...
      When i run M280 P0 S10 pin is deployed.
      Config:
      ; generated by RepRapFirmware Configuration Tool v3.1.9 on Sat Nov 28 2020 15:24:08 GMT+0100 (Midden-Europese standaardtijd)
      M550 P"Roy's 3D printer" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X160.00 Y160.00 Z800.00 E837.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E96000.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X24000.00 Y24000.00 Z540.00 E1200000.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E8000.00 ; set accelerations (mm/s^2)
      M906 X950 Y950 Z1300 E1100 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X400 Y400 Z500 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      ;M307 H7 A-1 C-1 D-1
      M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
      M558 P9 C"^!zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
      M557 X0:300 Y0:300 S20 ; define mesh grid
      M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
      M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
      M563 P0 D0 H1 F0:1 ; define tool 0
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @Roy last edited by
        @Roy Remove the bang, !, in front of the zprobe.in the M558.
        • Roy
          Roy last edited by
          YES it working! Thank you very much
