Heater N/A after 3.0 update
  • ; Heaters
    M140 H-1 ; disable heated bed (overrides default heater mapping)
    M308 S0 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin e0temp
    M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
    M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M143 H0 S280 ; set temperature limit for heater 0 to 280C
    I am not using a heated bed, This is the config data I got from RRF config tool 3.0. I can not figure it out I am using using e0heater and e0thermistor using an E3D hotend and thermistor
    Please post your complete config.g file.
  • ; Configuration file for Duet WiFi (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.1.9 on Sun Nov 29 2020 13:25:11 GMT-0800 (Pacific Standard Time)
    M550 P"My Printer" ; set printer name
    M669 K1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M350 X256 Y256 Z256 I0 ; configure microstepping without interpolation
    M350 E16 I1 ; configure microstepping with interpolation
    M92 X1280.00 Y1280.00 Z6666.00 E256.00 ; set steps per mm
    M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X1200 Y1200 Z1200 E1800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X590 Y590 Z590 S0 ; set axis maxima
    M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
    M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
    M557 X15:215 Y15:195 S20 ; define mesh grid
    M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
    M563 P0 D0 F0 ; define tool 0
  • Moderator
    Can you send M122 and M98 P"config.g" and report the results of both?
  • @Phaedrux said in Heater N/A after 3.0 update:
    M98 P"config.g"
    m122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-917DA-G4MS8-6JKDD-3SJ6N-18VV9
    Used output buffers: 3 of 24 (6 max)
    Static ram: 30516
    Dynamic ram: 91460 of which 316 recycled
    Exception stack ram used: 240
    Never used ram: 8540
    Tasks: NETWORK(ready,688) HEAT(blocked,1340) MAIN(running,3676) IDLE(ready,156)
    Owned mutexes:
    Last reset 00:01:03 ago, cause: power up
    Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8540 bytes (slot 0)
    Error status: 0
    Free file entries: 10
    MCU temperature: min 17.9, current 21.8, max 22.2
    Supply voltage: min 26.5, current 26.6, max 26.8, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-11-29 19:36:41
    Cache data hit count 165231856
    Slowest loop: 14.40ms; fastest: 0.09ms
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    === AuxDDARing ===
    Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 15.47ms; fastest: 0.00ms
    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.23
      WiFi MAC address ec:fa:bc:2d:e2:c6
      WiFi Vcc 3.41, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 25352
      WiFi IP address 192.168.1.92
      WiFi signal strength -30dBm, reconnections 0, sleep mode modem
    M98 P"config.g"
    HTTP is enabled on port 80
    FTP is disabled
    TELNET is disabled
    Tool 0 offsets: X0.00 Y0.00 Z0.00
  • @Ironman777 said in Heater N/A after 3.0 update:
    you have not assigned a heater to your tool.
    H0 is missing
  • Moderator
    You should probably update to 3.1.1 as well.
  • @Veti
    its there
    i also tried M563 P0 D0 F0 ; define tool 0
    It still reads N/A
    I believe the board is bad I tried going back to original config and firmware with the same results. The only reason i tried to upgrade firmware because power off resume stopped working with no changes at all to printer firmware or config.
    its there
    thats not the M563 assignment
