    Spoted a little bug on Z prob I think
    • Donpiundefined
      Donpi
      when I home Z and the blTouch senor is allready triggered.
      I get the message that the sensor is allready triggered and no z movement.
      This is the expected behaviour, I hope.
      What I think is a bug is that the Z change state to homed.
      I think It should remain unhomed.
      I use RFF 3.1.1, a Duet 3 and a blTouch.
      And here is my homez.g
      ;Clear bed transformation
      N561
      ;Goto prob position
      G91
      G1 H2 Z5 F6000
      G90
      G1 X150 Y70 F6000
      G91
      ;Reset sensor
      M280 P0 S160
      ;Rough prob
      M402 ; Retract prob
      M401 ; Deploy prob
      G1 H1 Z-305 F6000
      M402 ; Retract prob
      ;Down 5mm
      G1 H2 Z5 F6000
      ;Fine prob
      M402 	; Retract prob
      M401 	; Deploy prob
      G30 	; Prob
      M402 	; Retract prob
        I agree, it should remain not homed. I will test this.
          It's not a bug, it's because you are using the Z probe as an endstop switch in this line:
          G1 H1 Z-305 F6000
          That will mark Z as homed.
          You should use a G30 command for that line too. You can use M558 to set the probing speed (F parameter) to a higher value before the first G30 command, and restore it to the usual value for the second.
          Donpiundefined 1 Reply Last reply Reply Quote 1
          • Donpiundefined
            Donpi @dc42
            @dc42 haha great I did as you said and by the way removed all those unnecessay M401 and M402.
            Now it remains not homed.
            Thank you.
            • A Former User?
              A Former User
              N561
              Also I think your code N561 is wrong.
              I think it should be M561: Set Identity Transform
              • Donpiundefined
                Donpi @A Former User
                @CaLviNx Thanks I didn't see this.
                By the way it explain some weird behaviour I had in the past 😛
