    DUET 3 + SBC : Powering external device with 12V from DUET 3
    • Donpiundefined
      Donpi
      Can I use the 12V socket that is between OUT 8 and TEMP 2 to power a LED strip ?
      Actualy I use OUT 4,5 and 6 as pwm pin to power my RGB LED strip but I need them to other things.
      So my plane is to use an arduino to drive the LED strip and le RPI to intercept some custom GCODE to send the values to the Arduino.
      I know it'a bit wreid. But I'm open to suggestions 😛
      Bye
      Juan
      • Vetiundefined
        Veti
        see
        https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_12V
        with the max of 0.8A this is not something you would want to put a lot of leds on.
        it would be better to use a buck converter.
        Donpiundefined 1 Reply Last reply Reply Quote 1
        • Donpiundefined
          Donpi @Veti
          @Veti Yeah I'have 50 LED it's like 3A or so.
          I have plenty of LM317T, I'll try something directely from the 24V power supply.
          Thanks.
            Why not use a 24V LED strip?
            Donpiundefined 1 Reply Last reply Reply Quote 0
            • Donpiundefined
              Donpi @dc42
              @dc42 It's beacause I allready have one 12V.
              But yeah, I'am looking that way too.
