Extruder Drives error ( Drive 0 = 9999.9)
Hi community, this is my first post at this blog, so first of all, thanks in advance for any kind of help, everything is welcome!
I am trying to print with dual extruders and at some point the extruder stops extruding material and on the status screen I can see that my Drive 0 has reached 9999.9, and it is not working anymore.
This happens randomly during the print, and I don't have any kind of idea about why this is happening.
Any kind of help is more than welcome, thanks.
want to start by posting your config?
; Configuration file for Duet Ethernet (firmware version 1.20 or newer)
; generated by RepRapFirmware Configuration Tool on Mon Feb 05 2018 09:08:53 GMT+0100 (Hora estándar romance); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
; Automatic saving after power loss is not enabled;Z probe BLTouch
M557 X63:158 Y50:145 S9 ; define probing gride from X=80 to 180, Y=90 to 190mm with a mesh spacing of 10mmM307 H6 A-1 C-1 D-1 ;Confugire heater 6 (PWM 4) as control for BLTouch
M558 P9 H10 F100 T2000 A4 S0.05 ;Configure probe type
G31 X0 Y-35 Z-25 P25 ;Offset probe-Nozzle;Configure external triggers, optic sensor, extruder limit
M569 P0 S1 ; Drive 0 goes forwards X
M569 P1 S0 ; Drive 1 goes forwards Y1
M569 P2 S0 ; Drive 2 goes forwards Z
M569 P3 S0 ; Drive 3 goes forwards Y2 (U)
M569 P4 S0 ; Drive 4 goes forwards E paste
M569 P5 S0 ; Drive 5 goes forwards E FDMM584 X0 Y1:3 Z2 U8 V9 E4:5 P3 ; Apply custom drive mapping
M350 X16 Y16:16 Z16 U16 V16 E16:8 I1 ; Configure microstepping with interpolation
M92 X320 Y320:320 Z320 U320 V819 E819:417 ; Set steps per mm
M566 X100 Y100:100 Z50 U100 V100 E100:2 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000:6000 Z3000 U6000 V300 E300:500 ; Set maximum speeds (mm/min)
M201 X100 Y100:100 Z100 U100 V50 E50:1500 ; Set accelerations (mm/s^2)
M906 X1800 Y1800:1800 Z1800 U1800 V1200 E1200:1680 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
M208 X0 Y0 Z-5 U0 V0 S1 ; Set axis minima
M208 X200 Y180 Z93.1 U200 V75 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z2 U1 S0 ; Set active low endstops for X, Y, Z
M574 V1 S0 ; Set active high endstop for E paste;define relay outputs (neumatic system)
M307 H5 A-1 C-1 D-1 ;disable heater 5 for relay output
M307 H2 A-1 C-1 D-1 ;disable heater 2 for relay output;define heaters
M305 P0 R4700 T100000 B3950 ; set bed thermistor parameters
M305 P3 R4700 T100000 B3950 ; set FDM heater thermistor parameters
M307 H0 A116.2 C1058.1 D2.6 V21.6 B0 ; set PID parameters bed heater
M307 H3 A275.3 C82.7 D4.4 V23.9 B0 ; set PID parameters FDM heater; Tools
M563 P0 D0 S"PASTE" ; Define tool 0
G10 P0 X0 Y0 Z1.1 ; Set tool 0 axis offsets
M567 P0 E1 ;define mix ratioM563 P1 D1 H3 S"FDM" ; Define tool 1
G10 P1 X54 Y-7.5 Z-16.7 ; Set tool 1 axis offsets
M567 P1 E1 ;define mix ratio; Network
M550 PTRANSPORT-PRINTER ; Set machine name
M540 PBE:EF:5E:AD:4D:18 ; Set MAC address
M552 P192.168.84.18 S1 ; Enable network
M553 P255.255.255.0 ;Set NetmaskM586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable TelnetG54
T0 ; Select Tool
M571 P2 S1 ; turn on logical pin 2 while extrusion is commandedM375 P"CustomHeightMap.csv" ; Load Height Map for grid compensation
@Oriol said in Extruder Drives error ( Drive 0 = 9999.9):
this does not work. the duet wifi can only do interpolation at x16
if you really are on firmware veresion 1, you need to update.
In general settings says that the version I am using is Duet Web Control 2.0.4
Is this related to your comment? Thnaks.
post the output from M115
please update to at least 2.05.1
better would be rrf3, but that means a changed config.
Great, I will try it and see if it works. Thanks.
Can you post the gcode file you're trying to print?
Do you get any error messages in the console?
