    Core XY Inverted Axis & Endstop Issues
    • Shiven
      Shiven last edited by
      Hi All,
      Have built my 3d Printer (Hypercube - Core XY Design) and have been running it on RAMPs the last couple of weeks. All went well and i've got some decent calibration prints out of it. The printer itself is functional.
      I've just migrated my way over to the DuetWifi, and have been fiddling about with anything and everything i can find to get a handle on how it all comes together; I've found myself in a spot of bother however. Following this article in particular: https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_CoreXY_printer
      if i run;
      [[language]]
      M569 P0 S0
      M569 P1 S0
      G91 G1 S2 X10 F3000
      G91 G1 S2 Y10 F3000
      These appear to function as intended; origin at front left of cube, +y is towards the rear of the cube, +x is to the right of the cube and their respective negative counterparts. This suggests that my motors are running as i'd expect them to.
      I come along to the front page of the wifi control, click x+10, and y+10 triggers. As the code above (& the page) suggests that my motors are in their correct holsters, has anyone got an idea as to why that is the way it is? I'll attach my config below.
      I have one further issue, this is to do with Endstops however. As above, i hit Y-100 and then trip my Y endstop by hand. The system does come to a halt but there seems to be a significant delay between the trigger occurring and the system actually stopping. My X carriage was able to move 50mm or so before coming to a stop, AFTER the endstop had triggered.
      Configuration attached below, any help is much appreciated!
      [[language]]
      ; Configuration file for Duet WiFi (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Sat Jul 22 2017 23:44:03 GMT+0000
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M667 S1 ; Select CoreXY mode
      M208 X200 Y190 Z155 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
      M558 P0 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
      G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:185 Y15:175 S20 ; Define mesh grid
      M92 X87.489 Y87.489 Z4000 E420 ; Set steps per mm
      M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X1400 Y1400 Z1400 E1400 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S260 ; Set maximum heater temperature to 260C
      M563 P0 D0 H1 ; Define tool 0
      M550 PHypercube ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S1 ; Enable FTP
      M586 P2 S0 ; Disable Telnet
      Thanks!
      Shiven
      • deckingman
        deckingman last edited by
        1. Try swapping the one of the XY motor directions as both motors on a corexy contribute to movement. Usually (but not always) a corexy is something like M569 P0 S0 and M569 P1 S1.
        2. When doing a move such as Y-100, it'll only stop when it senses the end stop if you tell it to by using the S1 parameter. The buttons on the web interface use the default which is S0 (do not sense end stop). So if you do a slow move by sending G1 Y-100 S1 F(something low) the hit the end stop switch, it should stop instantly. If you don't stipulate S1, it'll ignore the switch. When you tried it, the move probably carried on until it hit the axis minima or maxima.
          1. You need to put the G91 on a separate line when testing the motor directions:
          G91
          G1 S2 X10 F3000
          G1 S2 Y10 F3000
          2. In RRF versions prior to 1.19, the X and Y motors are swapped compared to most other firmwares. So you probably need to swap your X and Y motor connections. Or you could upgrade to firmware 1.10beta10 instead, but read https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta first in that case.
          • Shiven
            Excellent, thanks guys.
            I've managed to resolve the issues as noted, here is my updated config.g for anyone lurking on this forum with the same issue. As stated each of these machines are different so ymmv.
            [[language]]
            M569 P0 S0 ; X Goes Forwards
            M569 P1 S1 ; Y Goes Backwards
            M569 P2 S0 ; Z Goes Backwards
            Off to fiddle!
            Thanks again~
