    Stuttering print, only on CW circles
    1.4k
      For the update to RRF3, start with 3.0 and then 3.1.1. You can generate a RRF3 config set using the online tool and then compare to your existing config to add in anything custom. Once it's running you can update to the beta (or RC if it's out by then.)
      • zemlinundefined
        zemlin
        With some help from the forum here I got one of my machines running 3.2 Beta4?
        No change in the stuttering. Tried 566 P1, that doesn't have an impact either.
        Update - found the 3.2.beta4.1, but since it was mentioned that anything after 3.2 would have the improved processing, not going to duplicate the tests unless you think it's worthwhile.
