Duet 3 6HC micro SD socket damaged, need to send for repair
I did some wiggle testing and found that the wiring from the duet 3 to the paneldue is flakey..... going to make a new cable and pay closer attention to the terminations... I always solder the wire ends before I crimp the terminal on the end... do you guys solder the terminal on to the wire as well?
A good crimp should be on bare wire. If you solder first the crimp won't work properly.
What gauge wire do you normally use with the crimps on the fans, sensors and steppers..?. I'm using nema 23 and 17 motors... I had been using 22 gauge wire
22 is likely just fine for those things.
it is likely that I do not have a good crimper for this task... what is the recommended crimper for this task?... my current problem is that when I crimp down on the terminal it cuts the wire end off and when I tine the wire ends before I crimp it solves this problem.
There are many options. https://forum.duet3d.com/topic/9852/crimping-tool/
many thanks... I'll get it ordered today... I'll leave you guys be for a while... headed to Cancun after christmas so it will be after that before I can get to this project... have a great holiday
