    Switching Y and Z stepper outputs on Duet2?
    • mcscottundefined
      mcscott
      Hey gang! First time caller, long time listener, and all that.
      I'm working on converting an existing printer to a Duet2 WiFi. The configuration is dual opposing Nema17 steppers on the Y-axis, and a single Nema23 for the Z-axis.
      What I'm wondering is since the Duet2 has outputs for dual Z steppers, is there a way to switch output of the Y and Z axis in the printer configuration settings?
      Or is that a bad idea, and I should just dual wire the two Y-axis steppers?
      Thanks!
      droftartsundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @mcscott
        @mcscott M584 in your config.g is what you want.
        Change from:
        M584 X0 Y1 Z2 E3
        to
        M584 X0 Y2 Z1 E3
        or something similar.
          Phaedrux Moderator @mcscott
          @mcscott said in Switching Y and Z stepper outputs on Duet2?:
          If you have a free driver you could have each Y stepper on it's own driver.
          Change from:
          M584 X0 Y1 Z2 E3
          to
          M584 X0 Y1:4 Z2 E3
