SD card
I recently purchased a Duet2 ethernet board . I
am having a great deal of trouble sorting the .sys files for the
SD card. The card delivered has test data on it and and directs
you to a RepRap site. This site gives details of what to input
to the SD card but this is quite old and I dont think it is
compatible with the firmware (2.05.1) It should be possible to
downoad the latest info from github but I download a .bin file
that I cannot open on my Windows 10 machine. Any advice and help
would be most welcome.
use the config tool to generate the appropriate sys files for your printer type.
https://configtool.reprapfirmware.org/
@jay_s_uk Thanks for that. I have used it and got a .sys file out of it. I have read somewhere that code S is now used in the latest firmware as a laser switch and now has to be replaced by H. Is this true and do I have to change S whereever it appears?
Thats only applicable to RRF3. Shouldn't cause you an issue if running 2.05.1.
The config tool automatically inserts the correct gcode
Nearly there! Downloaded the files using "Configuration tool 3.1.10". Initially got "insuficient homing" but this was cured with G92 X100 Y100 Z100. Slight problem - on initially homing X it overshot the end stop microswitch but then settle down. Now to connect the heaters and thermistors
