    Duet Ethernet stuck on pausing.
    • cbusilloundefined
      cbusillo
      Hi, my Duet Ethernet is stuck on pausing. It is currently not printing, but has the heaters on correctly.
      I am trying to get the pause command to run, but every time I used M600, M226, or the pause button, the Duet appears to freeze. Nothing I can do or send seems to get it out of "pausing" except for resetting the board.
      I am on the newest beta firmware. I cannot find anything related to this experience on the forum. M122 is included below. I welcome any suggestions before I hit the power button and restart this print again.
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta3.2 running on Duet Ethernet 1.02 or later
      Board ID: 08DAM-9K9K2-NGNSN-6J9DL-3S46Q-9RSBJ
      Used output buffers: 3 of 24 (24 max)
      Static ram: 24108
      Dynamic ram: 96412 of which 60 recycled
      Never used RAM 9468, free system stack 116 words
      Tasks: NETWORK(ready,164) HEAT(blocked,308) MAIN(running,422) IDLE(ready,20)
      Owned mutexes:
      Last reset 34:48:29 ago, cause: software
      Last software reset at 2020-12-08 21:58, reason: User, GCodes spinning, available RAM 9468, slot 2
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
      Error status: 0x00
      MCU temperature: min 15.6, current 26.4, max 27.4
      Supply voltage: min 24.2, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 52933, standstill, SG min/max 144/965
      Driver 1: position 63618, standstill, SG min/max 141/1010
      Driver 2: position 2149, standstill, SG min/max 105/1023
      Driver 3: position 0, standstill, SG min/max 0/1023
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2020-12-10 08:47:16
      Slowest loop: 116.95ms; fastest: 0.20ms
      === Storage ===
      Free file entries: 8
      SD card longest read time 3.0ms, write time 80.9ms, max retries 0
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 103, MaxWait: 67361790ms
      Bed compensation in use: mesh, comp offset -0.070
      === MainDDARing ===
      Scheduled moves 91403, completed moves 91403, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      Heater 0 is on, I-accum = 1.0
      Heater 1 is on, I-accum = 0.6
      Segments left: 0
      Movement lock held by File
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0 21, running macro
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 92.94ms; fastest: 0.02ms
      HTTP sessions: 2 of 8
      Interface state active, link 100Mbps full duplex
      === Filament sensors ===
      Extruder 0 sensor: ok
        Please update to 3.2 beta 4.1
        • cbusilloundefined
          cbusillo
          It seems to be working. The beta 4.1 wasn't on the releases page so I didn't know it existed. I'll do a real print with a pause in it after this current print. Thank you for the quick help.
          • cbusilloundefined
            cbusillo
            Everything is working now. Thank you so much for the quick help
