    Duet 3 6HC External TMC 2208 or 2209 with Stall Detection
    • Depundefined
      Dep
      All motor drivers on the board are used in my printer and I need another driver to connect the E3D Coupler motor. How can I connect an external driver to the Duet 3 board?
      I have a StepStick MKS TMC2208 and 2209.
      Please recommend how to connect it correctly in order to be able to set the motor current and use Stall Detection.
      • Vetiundefined
        Veti
        well there is the https://www.duet3d.com/Duet3Expansion1XD board to connect external stepper drivers.
        BUT
        this makes no sense in your case.
        for the same price you can get https://www.duet3d.com/Duet3Toolboard1LC which has a TMC2209 driver on it and is integrated better and offers more features.
        and with the first board you can not use stall detection.
        • Depundefined
          Dep
          This option is understandable. Unfortunately, I don't have this board right now.
          Is it possible to connect the driver directly to the board?
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @Dep
            @Dep said in Duet 3 6HC External TMC 2208 or 2209 with Stall Detection:
            no
            • Depundefined
              Dep
              Good. Thanks for the answer! I will then use the board you wrote.
