    SYS diectory in DeutPi.img not used
    Firmware installation
    • Stephen6309undefined
      Stephen6309
      In the os file, 2020-05-19-DuetPi.img. There are sys and macro directories. Why are they there if DWC and the Duet 6HC don't use them? I added my config files to sys and DWC still says I need to configure the system.
        jay_s_uk
        They're for using the sd card in standalone mode
        • A Former User?
          A Former User
          you can change the directory DSF uses in /opt/dsf/conf/config.json i believe. point it to /boot instead of /opt/dsf/sd and give the permissions a once over. (note not tried it myself!)
