M117 is spamming the web interface
I'm using PrusaSlicer,
I want to pause the print at a layer so I can manually do a color change.
After troubleshooting for over an hour, I found out my 3.2Beta3 had a M226 issue,
So now I'm using 3.2Beta4The M226 command now properly runs my pause.g command,
But my the M117 command that Prusaslicer automatically bakes into my GCODE is just spamming the web interface like crazy. It won't stop, even after I resume the print, there's all these blue message pop spam,
And all the message spamming makes the web interface ignore some of my mouse clicks to extrude/resume/etc.
Here's an example,
G1 X273.205 Y115.030 E144.84155
G1 X273.520 Y114.311 E144.87830
G1 X273.712 Y114.007 E144.89516
;Z:1.55
;HEIGHT:0.25
G1 Z1.610 F12000.000
;PAUSE_PRINT
M117 "System is Paused"
M226
G1 X260.156 Y113.628
;TYPE:Perimeter
G1 F3064
G1 X278.764 Y113.628 E145.76703
G1 X278.764 Y132.235 E146.63891
G1 X260.156 Y132.235 E147.51078
You need to update your web interface to match the firmware you have.
Try uploading this one
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2beta4/DuetWebControl-SD.zip
