    if with calculation for color
    Gcode meta commands
    • happyundefined
      happy
      I am trying to get LED lights changing with the status of the print.
      I setup my deamon.g as follow:
      ; deamon.g
      ; adapting lights to print progress
      if job.layer == null
       ; No job started - initial start of machine
       M42 P0 S0 ; Red
       M42 P1 S0 ; Green
       M42 P2 S0.1 ; Bleu
       M42 P3 S0.1 ; White
      else
       if heat.heaters[0].active > 0
        if heat.heaters[1].active > 0
         if job.layer != 0
          ;if job.timesLeft.file < 100
          if {job.filePosition / job.file.size} >= 0.95
           ;end of print
           M42 P0 S0 ; Red
           M42 P1 S1 ; Green
           M42 P2 S0 ; Bleu
           M42 P3 S0.1 ; White
          else
           ;middle of print
           M42 P0 S1 ; Red
           M42 P1 S0 ; Green
           M42 P2 S0 ; Bleu
           M42 P3 S1 ; White
         else
          ; bed and head heating
          M42 P0 S0.5 ; Red
          M42 P1 S0 ; Green
          M42 P2 S0 ; Bleu
          M42 P3 S0 ; White
        else
         ; bed heating
         M42 P0 S0.1 ; Red
         M42 P1 S0 ; Green
         M42 P2 S0 ; Bleu
         M42 P3 S0 ; White
       else
        M42 P0 S0 ; Red
        M42 P1 S0 ; Green
        M42 P2 S1 ; Bleu
        M42 P3 S0 ; White
      My problem is that "if {job.filePosition / job.file.size} >= 0.95" doesn't want to work and throws a console error:
      Error: in file macro line 15 column 41: meta command: expected numeric operand
      I am note quite sure what is wrong.
      Could someone help?
      Thank you
      oc_geekundefined 1 Reply Last reply Reply Quote 0
      • oc_geekundefined
        oc_geek @happy
        @happy i was just trying to do the same and get the same error as yours.
        Have you sorted this out ?
        I wonder which type is "job.file.size" as i expected it the be numerical...
          dc42 administrators @oc_geek
          @oc_geek I replied to your other thread.
