Adding Camera Duet2 Wifi RSTP problems & Chrome
Hi Guys
I got already very good help from you.So i will asked you if you has a solution to add a camera on Duet Web Control.
I buy a wyze Cam V2 , and i already make new Software on it.
So i have access to Camera via Chrome and typing ip into the browser.When i put the adress into Suet Web, i don´t get a Picture .
Is there special settings to do?Hope someone can help me.
I use the wyze Cam with dafang hack on my maestro...
You have to add user and pw in the https-link
Something like this: https://user:pw@xxx.xxx.x.xxx/cgi-bin/currentpic.cgi
Check the wiki: https://duet3d.dozuki.com/Wiki/How_to_include_a_web_camera_image_in_Duet_Web_Control#Section_WyzeCamV2 -
Thank you for your reply.
I try this, but without function.
Do i have to restart the Duet board?
Or are there other special settings on Duet Web ?
Does it works with Chrome Brwoser? -
@uneumann36
I use Firefox
Can you try to open the link (with pw+user) in a chrome tab. That should show you the still picture... -
Hi, Thank you for your reply.
Yes this Works. -
@uneumann36
Then you have to play around with the settings in the DWC tab. Uncheck fix frame and embedded. -
Sadly, browsers no longer support RTSP. To get an IP camera to show up in DWC, it needs to have a facility to serve a still image.
The wyze cam with modified fw has a build in rtsp-server.....
Mine is working with DWC. -
@dc42 said in Adding Camera Duet2 Wifi RSTP problems & Chrome:
You are right, as always. it's depending on browser.....Only working in firefox.
Does this mean that a service like "motion" is required for chrome ? -
Probably, though there are alternatives to motion.
You might also be able to find a plugin/extension for chrome to bring back RTSP, but haven't tried it myself.
Thank you for all information.
So i am not a computer expert.
I play with this more then a week without function.Does anybody know how to adjust my mofified Wyze Cam or Chrome Browser or DWC that this work?
May step by step?
Or is there no possibility to get this working?Thank´s
It would be great if someone has an idea how to solve this.
What version of DWC are you using? Someone else just reported some problems in the recent betas as well.
Hi
i use Duet Web Control 2.0.7 -
Unfortunately I'm not familiar with the Wyze cams or how they are functioning, but since you are using an older DWC I would think that the methods posted above would still work.
Have you tested in firefox to confirm if it's working there?
Yeah Firefox is also not working.
RTSP isn't supported by modern browsers, so DWC doesn't support it either. You need to use mjpg or something else.
Ok, sorry for the question,
But how to do? -
I hope someone has an idea
