    Duet2 WiFi Firmware on Raise 3d E2 ?
    Firmware installation
    10.9k
    • Vetiundefined
      Veti
      yes, but my statement was, the firmware was updated to 3.0.
      there are config changes you need to do as the rrf2 config does not work with rrf3.
      see
      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files
      without those changes you wont be able to move anything.
      • Proschi3Dundefined
        Proschi3D
        I'll keep trying tomorrow, thank you
        Love my Duet 3 Mini.
        https://www.instagram.com/proschi3d
        https://youtube.com/@proschi3d
        https://www.proschi3d.de
          Proschi3D
          the main problem now is that the printer doesn't start anymore.
          by start I mean that the display no longer starts up in the menu.
          it doesn't finish loading
          jay_s_ukundefined Vetiundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @Proschi3D
            @Proschi78 i guess you need to go back to 2.02 then
            Proschi3Dundefined 1 Reply Last reply Reply Quote 0
              Proschi3D @jay_s_uk
              @jay_s_uk that's exactly what I tried.
              it just didn't work out.
              the board stays at 3.0
              • Vetiundefined
                Veti @Proschi3D
                @Proschi78
                that might be a price to pay for running the original firmware on the raise 3d
                  Proschi3D @Veti
                  @Veti but unfortunately he no longer plays the original firmware on the board via the printer
                  • Vetiundefined
                    Veti
                    not sure what you mean
                      Proschi3D @Veti
                      @Veti https://support.raise3d.com/E2/how-to-update-the-motion-controller-firmware-20-1143.html
                      The printer does not do the firmware update because the board is flashed to 3.0
                      Vetiundefined 1 Reply Last reply Reply Quote 0
                      • Vetiundefined
                        Veti @Proschi3D
                        @Proschi78
                        yes but the firmware updated to 3.0. that is what you wanted to do in the first place.
                        a lcd screen is not necessary for the operation of a duet.
                          Proschi3D @Veti
                          @Veti said in Duet2 WiFi Firmware on Raise 3d E2 ?:
                          in my case it does 🙂
                          the WiFi module sits on the display controller
                          • Vetiundefined
                            Veti
                            @Proschi78 said in Duet2 WiFi Firmware on Raise 3d E2 ?:
                            in my case it does
                            well you might want to change the eol and line settings in yat so that you can see the actual status of the wifi module.
                              Proschi3D
                              i can only connect the motion board via usb.
                              the display controller is also operated via this interface
                              • Vetiundefined
                                Veti @Proschi3D
                                they can easily just route the spi lines to the display.
                                that is why the full M122 output is relevant.
                                you probably did not update the wifi firmware when you updated to the rrf3 firmware.
                                  Proschi3D @Veti
                                  I cannot update the WiFi firmware.
                                  because the wifi module is on a different board.
                                  and I have no access to it via the pc
                                  • Vetiundefined
                                    Veti
                                    the wifi firmware is not updated via the pc.
                                    see
                                    https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_WiFi_firmware
                                    but the M122 output is important
                                      dc42 administrators @Veti
                                      @jay_s_uk said in Duet2 WiFi Firmware on Raise 3d E2 ?:
                                      iap4e.bin
                                      did you rename it to Duet2combinesIAP.bin like the error message says?
                                      Duet2CombinedIAP is not the same as iap4e.bin! Renaming it will not work. You can get Duet2CombinedIAP.bin from one of the RRF 3.x releases.
                                      Proschi3Dundefined 1 Reply Last reply Reply Quote 1
                                        Proschi3D @dc42
                                        @dc42 can I go back from V3.0 to V2.02 that easily?
                                          jay_s_uk @Proschi3D
                                          @Proschi78 that'll be why the downgrade didn't work then.
                                          use the IAP file dc42 linked to and the firmware from my google drive
                                            Proschi3D @jay_s_uk
                                            @jay_s_uk ok i will try today at noon
