    PWM Expansion
    385
    • 3dMLundefined
      3dML
      What is my best option for adding at least 4 or more pwm outputs to the Duet2 Wifi? At the moment I have a BLTouch, RPM to pb6, and most of the thermistors pins used on the expansion connecter. I have no need for any additional stepper motor drivers.
      • Vetiundefined
        Veti
        have you used all 5 heater pins on the expansion port?
        • 3dMLundefined
          3dML
          I have not. I would prefer an expansion board of some type for cleaner wiring and also a lack of electrical component knowledge. If there is nothing reasonable I can use some external mosfets if someone will point me to the correct component and wiring diagrams. They will either be connected to fans or an ssr.
          • Vetiundefined
            Veti
            the duex5 has the 5 pwm ports.
            • 3dMLundefined
              3dML
              I have looked the duex5 but can't justify the cost for only a few pwm outputs. It also has 5 unnecessary stepper driver.
              Vetiundefined 1 Reply Last reply Reply Quote 0
                You can drive most SSRs directly from the heater control outputs on the expansion connector. Connect the SSR control input between +3.3V and the chosen heater control output.
                3dMLundefined 1 Reply Last reply Reply Quote 0
                • Vetiundefined
                  Veti @3dML
                  @3dML said in PWM Expansion:
                  then there is the duex2
                  • 3dMLundefined
                    3dML @dc42
                    @dc42 said in PWM Expansion:
                    Just to double check. The heater control output pins have a max voltage of +3.3V input? I have already burned up one processor from overvoltage.
                    • 3dMLundefined
                      3dML @Veti
                      @Veti said in PWM Expansion:
                      I have previously I have reached out to a number of my suppliers and no one has the duex2 available in the US.
                      • 3dMLundefined
                        3dML
                        Will it work to connect the PWM wire from a 4 wire 12v fan to a heater control outputs on the expansion connector?
                          dc42 administrators @3dML
                          It will probably work, however if the black fan wire becomes disconnected from ground then it is likely to damage the microcontroller.
