3.2Beta 4.1 reset - duet 3 mini5+ with SBC
I've been rebuilding my printer and during running the first test print the board reset.
Here's an output of M122m122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.2-beta4.1 running on Duet 3 Mini5plus Ethernet (SBC mode) Board ID: P2P4H-PA67A-G65J0-40TFU-L2D0Z-ZTS4L Used output buffers: 1 of 40 (10 max) === RTOS === Static ram: 98728 Dynamic ram: 119596 of which 24 recycled Never used RAM 42772, free system stack 200 words Tasks: Linux(blocked,101) HEAT(blocked,315) CanReceiv(blocked,967) CanSender(blocked,372) CanClock(blocked,363) TMC(blocked,105) MAIN(running,488) IDLE(ready,20) AIN(blocked,258) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:02:55 ago, cause: software Last software reset at 2020-12-17 11:14, reason: HeatTaskStuck, GCodes spinning, available RAM 42320, slot 1 Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0000080f BFAR 0xe000ed38 SP 0x2000ab84 Task MAIN Stack: 2001dfbc 0003035e 81000800 3f800000 40180000 4d8e8180 00000000 3e7f1f3e 3ddc9cf1 4530c6d4 4530c6d4 00000000 44b0c6d4 4301f53f 430aa7f0 00000000 3f800000 3f800000 3f800000 20000010 2001e530 200095b4 2001fe30 00000000 2001e530 00000080 a5a5a5a5 Error status: 0x00 Supply voltage: min 0.0, current 12.3, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, SG min/max 38/38, read errors 0, write errors 1, ifcnt 76, reads 25058, writes 12, timeouts 0, DMA errors 0 Driver 1: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 101, reads 25058, writes 12, timeouts 0, DMA errors 0 Driver 2: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 101, reads 25057, writes 12, timeouts 0, DMA errors 0 Driver 3: position 0, standstill, SG min/max 158/158, read errors 0, write errors 1, ifcnt 103, reads 25057, writes 12, timeouts 0, DMA errors 0 Driver 4: position 0, standstill, SG min/max 154/154, read errors 0, write errors 1, ifcnt 107, reads 25058, writes 12, timeouts 0, DMA errors 0 Driver 5: position 0, assumed not present Driver 6: position 0, assumed not present Date/time: 2020-12-17 11:17:42 Slowest loop: 1.69ms; fastest: 0.08ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 11.2MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === FreeDm 169 (min 169), maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 1581, send timeouts 1579, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 15 === SBC interface === State: 4, failed transfers: 0 Last transfer: 8ms ago RX/TX seq numbers: 41417/6275 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x0b13c Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0-beta4 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 35.00
Info from the pi syslog
Dec 17 11:14:27 duet3 DuetControlServer[1098]: [info] Job has been paused at byte 11404, reason User Dec 17 11:14:27 duet3 DuetControlServer[1098]: [warn] Lost connection to Duet (Timeout while waiting for transfer ready pin) Dec 17 11:14:27 duet3 DuetControlServer[1098]: [warn] Bad header checksum (expected 0xd0ff, got 0x2953) Dec 17 11:14:31 duet3 DuetControlServer[1098]: [warn] IPC#202: Client with outdated protocol version connected (got 8, want 10) Dec 17 11:14:31 duet3 DuetControlServer[1098]: [warn] IPC#203: Client with outdated protocol version connected (got 8, want 10) Dec 17 11:14:31 duet3 DuetControlServer[1098]: [warn] IPC#204: Client with outdated protocol version connected (got 8, want 10) Dec 17 11:14:47 duet3 DuetControlServer[1098]: [info] Connection to Duet established Dec 17 11:14:47 duet3 DuetControlServer[1098]: [info] Aborted job file Dec 17 11:14:47 duet3 DuetControlServer[1098]: [warn] Controller has been reset
Please upgrade to RC1 and check if the problem persists.
