Monitor what True Bed Levelling is doing?
@3dML said in Monitor what True Bed Levelling is doing?:
Use G30 Xnnn Ynnn
where X and Y is the **tool position** of the first probe point not the **probe position** as
To the best of my knowledge, at least as of 3.1.1 firmware, the X and Y parameters are ignored when no P parameter is present.
This post is deleted! -
You posted about using G30 Xnnn Ynnn which suggests that the X and Y are used - but they are not.
@fcwilt
That is true. My bad.I use
G1 Xnn Ynn G30
I forget that it is two commands. I will update my post. Thanks for pointing that out.
G1 Xnn Ynn
G30I forget that it is two commands. I will update my post. Thanks for pointing that out.
Now I happen to think that the X and Y parameters SHOULD work which would be consistent and avoid having to determine the correct X and Y values for the G1.
