UNSOLVED Installing DSF on a Banana-Pi-M3 with Raspbian OS
DSF Development
8
38
2.0k
  • undefined
    JayJay
    Hello All
    I have a Banana-Pi -M3 that I have running a version of Raspbian.
    Im trying to install the DSF package following the guidelines here
    I have the file "duet.3d.list" in the following location "/etc/apt/sources.list.d/duet3d.list"
    im not 100% sure if i have the contents on the file correct as the guide is not so clear.
    I put two lines in that file:
    deb https://pkg.duet3d.com/ stable armv7
    http://pkg.duet3d.com/dists/stable/armv7/binary-armhf/
    then when i run the commands
    wget -q https://pkg.duet3d.com/duet3d.gpg
    sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/
    sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg
    I get an error message :
    bash: https://pkg.duet3d.com/duet3d.gpg: No such file or directory
    Does anyone have any ideas where im going wrong ?
    undefined 1 Reply Last reply 19 Dec 2020, 22:04 Reply Quote 0
      A Former User
      I do wget -qO - "https://pkg.duet3d.com/duet3d.gpg" | sudo apt-key add - which essentially does the same thing, but it seems unadvisable to add they key like that ref:
      https://unix.stackexchange.com/questions/332672/how-to-add-a-third-party-repo-and-key-in-debian/582853#582853
      but i'd guess you have some sort of formatting error that causes bash to look for the url instead of passing it as a paramter to wget, how are you running the commands, copy paste, script, both?
      undefined 1 Reply Last reply 20 Dec 2020, 08:59 Reply Quote 0
      • undefined
        Stephen6309 @JayJay
        @JayJay pkg.duet3d.com/duet3d.gpg is not a web page.
        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
          A Former User
          weather or not its a web page is kinda irelevant as its served by a web browser server and downloaded by a web client according to the instruction he listed and you linked to - but somehow OP is passing the url to bash instead of wget.
          • undefined
            JayJay @A Former User
            @bearer
            Thank you very much for taking the time to reply.
            I have tried inputing each command by manually typing each line in the terminal and I also tried copy paste and still the same occurs i will try the command you listed and see what happens.
            thank you again.
            • undefined
              JayJay
              im logged in as root and if i try using the code that @bearer listed i get the following error message
              gpg: key DA91C86B: no valid user IDs
              if i follow the link posted by @Stephen6309 i can input the following codes successfully :
              wget -q https://pkg.duet3d.com/duet3d.list
              sudo mv duet3d.list /etc/apt/sources.list.d/duet3d.list
              sudo chown root:root /etc/apt/sources.list.d/duet3d.list
              And with the code
              sudo apt-get install apt-transport-https
              It tells me everything is already the newest version
              But then when i type in :
              sudo apt-get update
              I receive the following error message
              W: GPG error: https://pkg.duet3d.com stable InRelease: Unkown error in executing gpgv
              when i try to use the command
              sudo apt-get install duetsoftwareframework
              it reads the packing list, then builds the depeendency tree and reads the "state" information then reports the following:
              *Some packages could not be installed. This may mean that you have requested an inpossible situation or if you are using the unstable distribution that some required packages have nopt yet been created or have been moved out of Incoming.
              The following information may help resolve the situation:
              the following packages have unmet dependencies:
              duetsoftwareframework :
              Depends : duetcontrolserver (= 3.1.1) but it is not going to be installed
              Depends : duetsd (= 1.0.6) but it is not going to be installed
              Depends : duettools (= 3.1.1) but it is not going to be installed
              Depends : duetwebserver (= 3.1.1) but it is not going to be installed
              Depends : reprapfirmware (>= 3.1.1-1) but it is not going to be installed
              Depends : reprapfirmware (<= 3.1.1-999) but it is not going to be installed
              E: Unable to correct problems, you have held broken packages *
              ? 1 Reply Last reply 20 Dec 2020, 11:31 Reply Quote 0
                A Former User
                Not familiar with the banana pi, can you share the output from uname -a and cat /proc/cpuinfo?
                ? 1 Reply Last reply 20 Dec 2020, 11:26 Reply Quote 0
                  A Former User @A Former User
                  This post is deleted!
                    A Former User @JayJay
                    @JayJay said in Installing DSF on a Banana-Pi-M3 with Raspbian OS:
                    btw seems to sugget bananapi with raspios/raspbian isnt fully compatible because it works just fine on the regular pi with regular raspios:
                    pi@raspberrypi:~$ wget -qO - "https://pkg.duet3d.com/duet3d.gpg" | sudo apt-key add -
                    OK
                    pi@raspberrypi:~$
                    ? 1 Reply Last reply 20 Dec 2020, 11:37 Reply Quote 0
                      @bearer
                      The bananapi runs an ARMv7 processor, so it "should" work
                      Duet Software Framework resembles a collection of programs to control an attached Duet3D board from a Linux-based mini computer (SBC). Since it is using .NET Core, it requires an ARM processor that supports ARMv7 instructions processor is required
                      For clarity: I'm successfully running a banana-pi with DSF and i followed the guide the OP listed so im not sure why it worked for me but not him.
                      • undefined
                        JayJay
                        uname -a :
                        Linux bpi-iot-ros-ai 3.4.39-BPI-M3-Kernel #1 SMP PREEMT Sat May 26 10:03:38 UTC 2018 arm7l GNU/Linux
                        cat /proc/cpuinfo:
                        Processor : ARMv7 Processor rev 5 (v71)
                        processor : 0
                        BogoMIPS : 4800
                        processor : 1
                        BogoMIPS : 4800
                        processor : 2
                        BogoMIPS : 4800
                        processor : 3
                        BogoMIPS : 4800
                        processor : 4
                        BogoMIPS : 4800
                        processor : 5
                        BogoMIPS : 4800
                        processor : 6
                        BogoMIPS : 4800
                        processor : 7
                        BogoMIPS : 4800
                        Features : swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt
                        CPU implementer : 0x41
                        CPU architecture : 7
                        CPU Variant : 0x0
                        CPU Part : 0xc07
                        CPU Revision : 5
                        Hardare : sun8i
                        Revision : 0000
                        Serial : 50300102008add2ed0e
                        @CaLviNx
                        you say you have this running on a bananapi, would you be able to share your image if that is even possible.
                        ? ? 2 Replies Last reply 20 Dec 2020, 12:06 Reply Quote 0
                          @JayJay
                          I'm not sure how to do that!
                          My banana-pi is an older M2 (says its an ARMv7 too though)
                          EDIT: im running Debian not raspbian (dont know if that makes a difference or not)
                          OS im running
                            That's not raspbian/raspios is it?
                            undefined 1 Reply Last reply 20 Dec 2020, 15:55 Reply Quote 0
                            • undefined
                              @bearer
                              well im not sure what its telling you, im a new user to linux in general , I just downloaded the version of raspbian from the bananapi forum my thinking was that if I used a bananapi version of raspbian I would have a better chance of success .
                              Raspbian for Bpi
                              jay_s_ukundefined 1 Reply Last reply 20 Dec 2020, 16:06 Reply Quote 0
                                jay_s_uk @JayJay
                                @JayJay you may be able to succeed with armbian
                                undefined 1 Reply Last reply 20 Dec 2020, 16:57 Reply Quote 0
                                • undefined
                                  JayJay @jay_s_uk
                                  @jay_s_uk
                                  i will try it thank you
                                  • undefined
                                    JayJay
                                    So progress or a sort.
                                    two steps forward and five back...
                                    I installed armbian THANK YOU @jay_s_uk which successfully allowed me to install DSF.
                                    I set the buffer size as requested, and according to the bananapi docs the M3 has the same pinout as a Rpi.
                                    I now get a new issue !!
                                    When I run : sudo systemctl start duetcontrolserver
                                    It outputs the following:
                                    Dec 20 19:30 bananapim3 DuetControlServer [724] : Started Duet control Server
                                    Dec 20 19:30 bananapim3 DuetControlServer [724] : Duet control Server v3.1.1
                                    Dec 20 19:30 bananapim3 DuetControlServer [724] : Written by Christian Hammacher for Duet3D
                                    Dec 20 19:30 bananapim3 DuetControlServer [724] : Licensed under the terms of the GNU Public License Version 3
                                    Dec 20 19:30 bananapim3 DuetControlServer [724] : [info] Settings Loaded
                                    Dec 20 19:30 bananapim3 DuetControlServer [724] : [Info] Environment initialized
                                    Dec 20 19:30 bananapim3 DuetControlServer [724] : [fatal] Could not connect to Duet (error 517. Cannot put line into event mode)
                                    And that then starts a loop
                                    Ideas ?
                                    chrishammundefined 1 Reply Last reply 23 Dec 2020, 11:06 Reply Quote 0
                                      A Former User
                                      You might need the gpio library used? (Sorry can't remember the name, but if you look for the loopback test thread i think it's mentioned there).
                                      edit: found the reference when on computer, so maybe try sudo apt-get install gpiod ?
                                      undefined 1 Reply Last reply 20 Dec 2020, 22:41 Reply Quote 0
                                      • undefined
                                        @bearer
                                        I installed the library and still no go.
                                        i invited a friend over who has a raspberry-pi (3b+) we plugged that in with a copy of official Raspbian image and that worked perfect, so i now know its not the Duet-3 .
                                        i tried to get into armbian-config to set the spi but armbian-config->system->hardware throws up an error :
                                        armbian-config hardware error expected at least 6 tokens for checklist have 4 use --help to list options. submodule.
                                        • undefined
                                          JayJay
                                          @bearer
                                          So i got raspbian to actaully install the DSF package but i now have an error which is evidently linked to the SPI connection not being activated.
                                          As i get the following error
                                          [Fatal] could not connecto to Duet (error 2 cannot open GPIO device file  '/dev/gpiochip0/
                                          I am not a linux user and I am not that good with coding so i really need a idiots step by step guide on what i need to do to enable the SPI
                                          on the banana-pi (even with raspbian) there is NO section in raspi-config to enable the SPI
                                          so im at a loss as to how i go about enabling it and i looked at some of the online guides on how to do this and i became very very lost as it is all greek to me.
                                          i installed RPI.GPIO but how to actually use it and configure things again all greek to me.
                                          is anyone able to advise ?
                                          2 out of 38
