Duet Maestro 2 Wifi BLTouch Issue
I blue up my old Duet Maestro 2 Ethernet a few weeks ago by shorting out the mosfet for the heater. So I ordered a replacement and this time got the Duet Maestro 2 Wifi. I immediately upgraded the firmware to 3.1.1 since it was a new config build. The issue I am having is that the BLTouch is not responding at all. As soon as I turn on the printer the BLTouch is flashing red and the probe stays in whatever the last position it was in. The Z-Probe on the status screen always shows Z-Probe = 1000.
I have the wiring for the BLTouch hooked up to the dedicated 4 pin connector on the board. From front to back of the board, the BLTouch is wired as such:
- White
- Black/Brown
- Orange
- Red
In Config.g this is my Z-Probe settings:
M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh gridHere is my deployprobe.g:
; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.1.10 on Sat Dec 19 2020 20:28:49 GMT-0500 (Eastern Standard Time)
M280 P0 S10 ; deploy BLTouchHere is my retractprobe.g:
; retractprobe.g
; called to retract a physical Z probe
M280 P0 S90 ; retract BLTouchAnd finally, here is my homez.g:
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.1.10 on Sat Dec 19 2020 20:28:50 GMT-0500 (Eastern Standard Time)
G91 ; relative positioning
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first probe point
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioningThe BLTouch worked perfectly when I was using it with my old Duet Maestro running old firmware but does not work with the new firmware. I have searched high and low to try and find out why it isn't working.
Anyone able to help me out?
@PUGCanada said in Duet Maestro 2 Wifi BLTouch Issue:
there is no wifi version of the maestro.
did you get the duet 2 wifi? the zprobe.mod on the 2 wifi is not pwm capable.
Exactly what I needed. Everything is working now. Thank you!
