UNSOLVED How to turn on duet3-3hc using 5v supply?
Hi @dc42 , Hope you doing well.
I want to power on duet3-3hc Expansion board on 5v, like main-board.
I planned to connect This commponentsto
here, on 5V_EXT and 5V_INT pin. For 5V_EXT from one of the IO_X(5V_EXT) header pin and for 5V_INT test pin_23(TP23) of duet 3 expansion board.
- Will it cause any issue After I power on 12/24V main power supply?
Thanks.
